solidus28 12 Posted December 8, 2015 Author Posted December 8, 2015 Any news on this. I haven't updated the latest server version I saw today, but the changelog didn't sound like it changed anything for this issue.
ebr 16332 Posted December 8, 2015 Posted December 8, 2015 I haven't seen anyone report issues like this with the past couple of server versions.
solidus28 12 Posted December 8, 2015 Author Posted December 8, 2015 (edited) Oh. I quit reporting it because it seemed like everyone was being referred to this thread. I'm currently on 3.0.5781.4 and I still have to restart the app on my server at least daily or EMC hangs and presents me with No Items. No change in my performance. Unless 3.0.5781.5 introduced something. Did a fix actually go in with one of the server version? I've been watching in anticipation, but none of the updates sounded like they were related. Edited December 8, 2015 by solidus28
ebr 16332 Posted December 8, 2015 Posted December 8, 2015 I'm not aware of anything specific but, as I said, no one has said anything in a few weeks. I'm also not sure we really know why your server is timing out those responses.
bxsteez 3 Posted December 8, 2015 Posted December 8, 2015 Oh. I quit reporting it because it seemed like everyone was being referred to this thread. I'm currently on 3.0.5781.4 and I still have to restart the app on my server at least daily or EMC hangs and presents me with No Items. No change in my performance. Unless 3.0.5781.5 introduced something. Did a fix actually go in with one of the server version? I've been watching in anticipation, but none of the updates sounded like they were related. I had a similar issues so I uninstalled Emby Classic completely and deleted all the associated files and reinstalled. I had to install a beta since the website fails to install the stable version. That might help you as well. You can save all your configuration files so you don't have to set everything up again.
solidus28 12 Posted December 8, 2015 Author Posted December 8, 2015 Thanks, bxsteez. What config files should I save?
bxsteez 3 Posted December 9, 2015 Posted December 9, 2015 Thanks, bxsteez. What config files should I save? I only kept gamebrowser since its so hard to reconstruct that config file. I have random issues with no movies being present when I installed the mb3launch so if you are using that it might be the cause too. I honestly have no idea what the issue is but it happens on all my pcs and I've done all I could on the server. I honestly can't even install a stable release of Emby Classic. It even fails to install so who knows maybe it's just our systems.
solidus28 12 Posted December 10, 2015 Author Posted December 10, 2015 Sad to report after a full uninstall of EMC and install to 291, I still encountered 'No Items' today. I'm sure a restart of the server app will fix it, but no dice
bxsteez 3 Posted December 10, 2015 Posted December 10, 2015 Sad to report after a full uninstall of EMC and install to 291, I still encountered 'No Items' today. I'm sure a restart of the server app will fix it, but no dice Yea I had the same problem all day too. I tried reinstalling WMC and that failed so I reinstalled the Server app and as of right now it's been working but it's only been like 2hrs. I dunno what is going on.
solidus28 12 Posted December 23, 2015 Author Posted December 23, 2015 Is there any way to schedule a restart of the server?
ebr 16332 Posted December 23, 2015 Posted December 23, 2015 I don't think a server re-start is going to help. In fact, I believe it will hurt. What needs to happen is those queries need to get run once and then, after that, the system should be responsive. So, I know it isn't a good answer, but, if you bring it up and have the problem, you should be able to just re-start the app and have it work normally. 1
solidus28 12 Posted December 23, 2015 Author Posted December 23, 2015 Restarting Emby Server (app, not the OS) always fixes the issues for a while (<24 hours). When I encounter the 'No Items' on EMC, I can restart the client, exit and reenter, etc, but it continues to come up to No Items. Only after Logging into Emby Server and performing a restart from the dashboard does service return to normal. I'm not sure what's triggering it, but I typically restart around 6 or 7pm when I get home and start watching television. It's fine until I go to bed, so sometime between then and the next night at the same time, something happens that causes No Items again. I've uninstalled and reinstalled the client (although I've had the same issues on my Nexus 7 in the Emby app as well, so I still suspect it's on the server side). I have not un/reinstalled the server, but have been upgrading to the stable releases as they come up, but even as recent as last night, I still encountered No Items. Any other thoughts? I was thinking of just creating scheduled tasks to run each morning in Windows to kill MediaBrowser.ServerApplication.exe and start it back up a few seconds later. I know it's a bandaid, but the daily restarts are getting old. I'm ok with it, the rest of the household isn't happy
ebr 16332 Posted December 23, 2015 Posted December 23, 2015 There is a server restart plug-in in the catalog.
solidus28 12 Posted December 23, 2015 Author Posted December 23, 2015 That's awesome, never noticed that! Is there anything I can/should do to help try to get to the root cause? Or just set daily restarts as a workaround?
ebr 16332 Posted December 23, 2015 Posted December 23, 2015 No, I don't think there is anything else you can do at this point. The server should be improving on this front soon.
solidus28 12 Posted December 23, 2015 Author Posted December 23, 2015 Thanks, ebr! I'm happy you at least introduced me to the Server Restart plugin
Mustang Dave 5 Posted January 4, 2016 Posted January 4, 2016 Anything new on when this might be addressed... I never noticed if anyone else stated this or not but once my library fully populates the only category that may or may not still be affected are Movie content and I have to close EMBY and reopen and everything works. TV Shows, Animation, etc. works fine...
ebr 16332 Posted January 4, 2016 Posted January 4, 2016 Unfortunately, it needs to be addressed at the server end. We are working on it.
bxsteez 3 Posted January 15, 2016 Posted January 15, 2016 Anything new on when this might be addressed... I never noticed if anyone else stated this or not but once my library fully populates the only category that may or may not still be affected are Movie content and I have to close EMBY and reopen and everything works. TV Shows, Animation, etc. works fine... Thank god! I thought I was the only this was happening to. I started to think my server was failing again.
bxsteez 3 Posted January 27, 2016 Posted January 27, 2016 @@ebr is there any update on this? It seems as emby gets upgraded the problem gets progressively worse. Is Emby for WMC development being put on the back burner these days?
ebr 16332 Posted January 27, 2016 Posted January 27, 2016 The issue isn't on the app side. Any perceived difference you are seeing with EMC updates is coincidental. What I suggest is limiting library scans to only when you really need them (use automatic monitoring if possible).
bxsteez 3 Posted January 28, 2016 Posted January 28, 2016 The issue isn't on the app side. Any perceived difference you are seeing with EMC updates is coincidental. What I suggest is limiting library scans to only when you really need them (use automatic monitoring if possible). That is currently what I'm doing. It is only updating when new content is added which I believe is the automatic monitoring but the lag is still present. When I click the emby app icon in WMC it loads up fast and then it freezes while it loads the images and what not and it freezes every I time i move to different type like Movies to TV to Games. It freezes to load the content. Sometimes it freezes for a very long time and then shows "No Items" in movies when I click in.
Dibbes 515 Posted January 28, 2016 Posted January 28, 2016 (edited) For me it means I have to restart the Emby service on the server, even if isn´t any scan running, wait for about 5minutes, then EMC can log in. Otherwise EMC just tries to log in, fails, returns to MCE. After restarting the Emby service, EMC will be able to log on, but will have lost theme settings in the process. This only if there was a failed log on previously though. I no failed log on, theme settings are kept. Edited January 28, 2016 by Dibbes
sleepy 10 Posted January 31, 2016 Posted January 31, 2016 Wow, just the same happened to me this morning! I fired up WMC as usual and my movies have vanished? I have no idea what has changed but no server restart, library rescan etc helps. Weirdly, Kodi is still working fine.
ebr 16332 Posted January 31, 2016 Posted January 31, 2016 Wow, just the same happened to me this morning! I fired up WMC as usual and my movies have vanished? I have no idea what has changed but no server restart, library rescan etc helps. Weirdly, Kodi is still working fine. And, if you wait about a minute and bring it back up is everything fine? If not, then this probably isn't the same thing.
