chali 11 Posted October 29, 2015 Posted October 29, 2015 Hi Im wondering if its possible to speed up emby server? for example, when my users browse the library it can take a long time before the images appear. Is it any way to give emby more ram or what does the delay depend on? The server have the following spec: Amd Optron 6386se, 16 gig ram (normally its 32 or 64gig but im testing some things) , and about 4 Tb of music and movies. using 5 drives in raid5 + the os and software is running on a ssd, network is 5x1gig in loadbalance Its running on ubuntu 14.04 x64. Its normally no problem being a couple of people playing movies and music, the "problem" is browsing the media and the time it takes for media to appear The memory usage is only 15-20% if 6 different movie streams are running and the cpu use about 8-10 cores at 40-80% off the 16 core available so what is making the browsing part so slow? Ps: sorry for the bad grammar /Regards
Luke 42243 Posted October 29, 2015 Posted October 29, 2015 it is probably just image scaling. as the apps build up their image caches the problem should largely go away.
