thisisvlad 1 Posted October 28, 2015 Posted October 28, 2015 Hello, I am using the new beta emby add-on for Kodi. First off, just wanted to say, it works amazingly! Set up was a breeze and it imported my library in no time at all . My question is about Rotten tomatoes ratings. when i browse my library in the browser version of emby, i see rotten tomatoes ratings. but i dont see these inside kodi. is there a way to make them show up? is it because i need a special skin? thanks for any help!
im85288 1493 Posted October 28, 2015 Posted October 28, 2015 Yes you need a skin that integrates this feature using the new skin helper addon. Kodi itself does not have the capacity to store rotten tomatoes ratings so the helper retrieves it and makes it available to compatible skins. The only one I'm aware off so far that shows this info is Eunique (see signature) but there may be others.
