preed88 0 Posted October 27, 2015 Posted October 27, 2015 I am at my wits end with this project. Recently I needed to rebuild my linux VM so I have installed emby on Ubuntu 14.04. Last night I had it successfully installed and working with no issue (alongside plex) Fast forward to this morning, and the app has now stopped working. My log file is empty (0 bytes). I have restarted the service and server several times. This is driving me crazy because the server use to work with no issues, now it seems as if the Linux side might not be worth the effort over just going Windows. When trying to access the web interface, I get connection refused (even from INSIDE the LAN) I have also ran the commands that show open ports and 8096 does not show up at all...
Luke 42243 Posted October 27, 2015 Posted October 27, 2015 it sounds like the server is not even running. are you sure it's started and that the process is running?
preed88 0 Posted October 27, 2015 Author Posted October 27, 2015 it sounds like the server is not even running. are you sure it's started and that the process is running? Thanks for the reply, and yes I am sure. Now that my syslog is updating, I am seeing a large amount of the following: Oct 27 13:17:16 MediaSRV /proc/self/fd/9: DEBUG: ADDRFAM='inet'#012EMBYSERVER='/usr/lib/emby-server/emby-server.sh'#012EMBY_BIN='/usr$ Oct 27 13:17:18 MediaSRV kernel: [ 5874.655760] init: emby-server main process ended, respawning Oct 27 13:17:18 MediaSRV /proc/self/fd/9: DEBUG: ADDRFAM='inet'#012EMBYSERVER='/usr/lib/emby-server/emby-server.sh'#012EMBY_BIN='/usr$ Oct 27 13:17:19 MediaSRV kernel: [ 5875.429298] init: plexmediaserver main process (21665) terminated with status 255 Oct 27 13:17:19 MediaSRV kernel: [ 5875.429316] init: plexmediaserver main process ended, respawning Oct 27 13:17:19 MediaSRV kernel: [ 5876.285142] init: emby-server main process ended, respawning Oct 27 13:17:19 MediaSRV /proc/self/fd/9: DEBUG: ADDRFAM='inet'#012EMBYSERVER='/usr/lib/emby-server/emby-server.sh'#012EMBY_BIN='/usr$ Oct 27 13:17:21 MediaSRV kernel: [ 5877.715358] init: emby-server main process ended, respawning Oct 27 13:17:21 MediaSRV /proc/self/fd/9: DEBUG: ADDRFAM='inet'#012EMBYSERVER='/usr/lib/emby-server/emby-server.sh'#012EMBY_BIN='/usr$ Oct 27 13:17:22 MediaSRV kernel: [ 5879.082938] init: emby-server main process ended, respawning Oct 27 13:17:24 MediaSRV kernel: [ 5880.759817] init: emby-server main process ended, respawning
Luke 42243 Posted October 27, 2015 Posted October 27, 2015 and the emby server log folder is full of 0 byte files?
preed88 0 Posted October 27, 2015 Author Posted October 27, 2015 I found the issue. Oddly, the filesystem had only 300mb free. After expanding it the service seems to be listening on the port now, and the log is actually filling with information. Thanks for your help
