Gina66 2 Posted October 26, 2015 Posted October 26, 2015 Not sure if this has been addressed or if there's an easy way to fix this or not. I've noticed with two of my TV shows that the episode title is wrong in both the Windows 10 app and watching episodes online. When I check the show folders, the correct episode is there, but when viewing, it says something else. I've enclosed an image link - http://goo.gl/ix5fMa So for example - In Spongebob Squarepants, Season 4 (the third episode, first row in the image), this is listed as 'Good Neighbors', episode 6, but it's not. It's actually 'Skill Crane'; it's labeled Skill Crane in my folder and the video plays Skill Crane. I did go into properties of the video and it states that it's 'Skill Crane'; I'm sure there's something about the video I need to change, but I can't figure out what exactly needs to be changed. The same is true for TMNT (2k3 version) - the first season seems fine, but as soon as I get into the arcs (Turtles in Space, Search for Splinter, etc), the episodes listed aren't what they should be. Now with this, I believe I do need to go back and label correctly, but I know I did it for the first two seasons. Is there anyway to change these so they actually show up correctly?
Happy2Play 9800 Posted October 26, 2015 Posted October 26, 2015 (edited) Well what is your naming convention? 'Skill Crane' is S04E05 Both providers say S04E06 is 'Good Neighbors' http://thetvdb.com/?tab=season&seriesid=75886&seasonid=9407&lid=7 https://www.themoviedb.org/tv/387-spongebob-squarepants/season/4?language=en Edited October 26, 2015 by Happy2Play
