Deihmos 170 Posted October 26, 2015 Posted October 26, 2015 (edited) I changed the posters to poster card but the setting does not stick. Is this the way it works? If I reload the browser I have to enable it again. Edited October 26, 2015 by Deihmos
Luke 42185 Posted October 26, 2015 Posted October 26, 2015 tests fine here on latest beta, view settings are remembered. make sure you're not in some kind of incognito mode or that browsing data isn't getting cleared for whatever reason.
Deihmos 170 Posted October 26, 2015 Author Posted October 26, 2015 I am not in incognito. I tried chrome, IE, Edge and they all do the same thing. If I refresh the browser, close or reopen it resets back to poster view. I did some more testing, I have all the other views disabled like suggestions and so on. If I enable them the view is saved.
Luke 42185 Posted October 26, 2015 Posted October 26, 2015 ok yes, i can see in that situation they're not saving. will be fixed for the next release.
