pir8radio 1313 Posted October 25, 2015 Posted October 25, 2015 Is there a way to set the view order for every user on the server at once? Movies, Music, Music Videos, Live TV, Playlists etc.... I don't mind if they change it on their own, but i would like to start with a uniform layout... I know i can go into each user and change them but that just sucks.... :-)
Solution Happy2Play 9800 Posted October 25, 2015 Solution Posted October 25, 2015 (edited) Have you looked at the Emby-Server\config\user\xxxxxxx\config.xml? Just a guess but couldn't you just copy it to each user folder since there is nothing that references the user except the folder it is in? Edited October 25, 2015 by Happy2Play 1
pir8radio 1313 Posted October 25, 2015 Author Posted October 25, 2015 I have not, every time I mess with the config files Luke yells at me.... Just kidding..... Yea I usually find most settings I am looking for already coded into emby somewhere, so I figured I would ask, maybe I was missing a setting somewhere... But a copy paste will be easy, i'll look into that...
