Hi All,
I am using a winfast dual tv  tuner card but for some reason Emby can't find it. I have also downloaded server wmc but it fails to open after installation.
I get The error message below:
"Recservice> failed to load EPG - uNRECOVERABLE EORROR - ServerWMC will terminate", I have tried both the older version & the newer version but both give the same error message.
Can anyone please advise a tv Tuner card that will work without any issues? I live in Australia so I would need to be able to buy in Australia.
Any help / Advise would be greatly appreciated. I would prefer a Tv Tuner card that would not need serverwmc if possible.
Regards
Brett.
Edited by BrettM
At this time emby can only natively use a hdhomerun that supports dlna. You would need to use a plugin like serverwmc. Serverwmc relies on a working configuration of Windows media center. Does your tuner work in Windows media center?
Hi,
Sorry I have been away and only just saw your reply,Thank you I had to configure windows media centre for it to work it's all good now.
