Happy2Play 9814 Posted September 29, 2020 Posted September 29, 2020 Everyone will have there own opinion but I would have to disagree with the plugin removing all the boxsets on removal.
ebr 16346 Posted September 29, 2020 Posted September 29, 2020 That behavior would be unwelcome by most and isn't what the plug-in is designed for. The point of the plug-in is to create known box sets automatically and it does that. Many people will use it initially to build the known ones and then remove the plug-in and modify/customize from there. It gives them a head start but then they can customize as they wish. 1
Luke 42255 Posted September 29, 2020 Posted September 29, 2020 The plugin doesn't remove boxsets, so there has to be something else going on.
Mick_K 7 Posted October 15, 2020 Posted October 15, 2020 Another question: Is there a way to remove [boxset] from the end of the folder path name using the Metadata Manager? currently I have the following: Path: /volume1/emby/data/collections/28 Days Weeks Later Collection [boxset] but I want it to be: Path: /volume1/emby/data/collections/28 Days Weeks Later Collection
Happy2Play 9814 Posted October 15, 2020 Posted October 15, 2020 7 minutes ago, Mick_K said: Another question: Is there a way to remove [boxset] from the end of the folder path name using the Metadata Manager? currently I have the following: Path: /volume1/emby/data/collections/28 Days Weeks Later Collection [boxset] but I want it to be: Path: /volume1/emby/data/collections/28 Days Weeks Later Collection No way that I know of. I believe it is hard coded in the server as removing it from collection name, removes the Collection from Emby.
Mick_K 7 Posted October 15, 2020 Posted October 15, 2020 (edited) 39 minutes ago, Happy2Play said: No way that I know of. I believe it is hard coded in the server as removing it from collection name, removes the Collection from Emby. Damn, not what I wanted to hear. Thanks anyway Happy. The reason I asked is because it's a tautology in a way (boxsets are collections but just using a different name). I use another program as an additional (if not main) metadata manager that also puts collections in the same folder and doesn't append the [boxset] to the end of the folder name so now I have two sets of collection data in the same folder. Not a huge concern other than I am doubling up on drive space unnecessarily since I can't remove [boxset] from the end of the folder path using Emby and I can't append [boxset] to the end of the folder path using the other program (automatically - I can do it manually). Edited October 15, 2020 by Mick_K Clarification
Carlo 4561 Posted October 18, 2020 Posted October 18, 2020 I had the same thought about boxsets and collections naming. Not sure what you mean by "doubling up" disc space? I just looked and 734 collections takes up 428MB of space which is nothing. How many collections are you going to have where the space the "duplicate collections" matters? They are just small text files.
Happy2Play 9814 Posted October 18, 2020 Posted October 18, 2020 On 10/14/2020 at 7:14 PM, Mick_K said: I use another program as an additional (if not main) metadata manager that also puts collections in the same folder What other program are you using? If you prefer the other program, it is extra step but you could not use Emby's Autobox set plugin and use a bulk renaming utility to suffix [boxset] to all boxset/collections created by your third party app. Assuming this app is creating usable info for Emby.
Mick_K 7 Posted October 18, 2020 Posted October 18, 2020 5 hours ago, cayars said: I had the same thought about boxsets and collections naming. Not sure what you mean by "doubling up" disc space? I just looked and 734 collections takes up 428MB of space which is nothing. How many collections are you going to have where the space the "duplicate collections" matters? They are just small text files. I meant that the other program (tMM) stores collections exactly the same way Emby does except without the [boxset] suffice eg: Emby stores the collection as: ...\emby\data\collections\28 Days Weeks Later Collection [boxset] tMM stores the collection as ...\emby\data\collections\28 Days Weeks Later Collection That means I have two folders containing the same metadata (xml file + several media picture files) for every single collection (hence the doubling up of data). Currently there is no way to alter Emby Autobox and tMM only allows you to edit the pathname manually for each collection (which I have done but it is extremely time consuming). 1
Mick_K 7 Posted October 18, 2020 Posted October 18, 2020 5 hours ago, Happy2Play said: What other program are you using? If you prefer the other program, it is extra step but you could not use Emby's Autobox set plugin and use a bulk renaming utility to suffix [boxset] to all boxset/collections created by your third party app. Assuming this app is creating usable info for Emby. tMM (tinyMediaManager). Unfortunately, tMM would not see the change in folder name if I used a bulk renamer. I have manually edited each collection in tMM to append the [boxset] suffix to the path name. It works but it is very time consuming initially to do this if you have several hundred collections.
