Longrifle 33 Posted December 4, 2013 Posted December 4, 2013 @@Luke thank you for that response, it is working now... didn't realize it had to be [boxset] not (boxset) or [box set]
Longrifle 33 Posted December 4, 2013 Author Posted December 4, 2013 running MB Server Version 3.0.5083.27698 I have all my box sets set up the same way, but somehow on a few sets it only recognizes the 1st movie in the series and treats it like a single movie. notice Die Hard and The God Father series don't show up correctly...... when I click on either one of these it will want to play and not show the rest of the movies. I also tried deleting all the backdrops and xml file etc.... on the next scan, all of it came back again. I also tried adding (box set) to the first folder in the series (example: Die Hard (box set) ) that did not work either. any ideas? I would appreciate the help. thank you.
Luke 42288 Posted December 4, 2013 Posted December 4, 2013 get rid of the movie.xml file. that's only for movies.
Luke 42288 Posted December 4, 2013 Posted December 4, 2013 And if MB3 created the movie.xml, it's because the requirements for boxsets listed in the wiki aren't being used. You need either [boxset] in the DIeHard folder name, or you need a collection.xml file inside.
