benjamoomin 3 Posted October 22, 2015 Posted October 22, 2015 Hi, I've got an issue when I play live TV through Emby on some channels it is defaulting to the narrated audio descriptive type audio stream (NAR) instead of the standard English (eng) stream as I'd like.I've updated my mpextended to 0.6.1 beta as per the pinned post by @@pünktchen but that hasn't made a difference. In mpextended config, in the Streaming section I have the Default Audio Language set to "en (English)" The channel I'm testing with this issue with is ITV2 (I'm in the UK) via freesat. When I try this channel through mediaportal it defaults to the Eng stream correctly, but (i'm not sure if this is important) I have noticed that if I go to select Audio Languange the NAR stream is number 1 and the Eng is number 2 in the list. Could it be defaulting to the first stream it comes across instead of select my preference of an English stream? I should probably note that I've using primarily the Android TV app on a Nexus Player but also tested this out on the web gui, same NAR stream is selected via both methods. Any help here would be really appreciated! Thanks
pünktchen 1410 Posted October 22, 2015 Posted October 22, 2015 Can you post please the Emby server log! I guess i know what the problem is... @@Luke what's the letter code that Emby expects from MediaSourceInfo for audio - en, eng or englisch?
benjamoomin 3 Posted October 22, 2015 Author Posted October 22, 2015 Attached are the transcode and server logs for when I've just tried to view itv2 and it selected the NAR audio. The following bit from the transcode log is the part where it is selecting the audio stream to use (I think!) Stream #0:0[0x30]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 720x576 [SAR 64:45 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x40](NAR): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 128 kb/s Stream #0:2[0x41](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s Stream #0:3[0x50](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x62](eng,eng): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006) -async is forwarded to lavfi similarly to -af aresample=async=1:min_hard_comp=0.100000:first_pts=0. [libx264 @ 054df4a0] using SAR=404/405 [libx264 @ 054df4a0] using cpu capabilities: MMX2 SSE2Fast LZCNT [libx264 @ 054df4a0] profile High, level 4.1 Output #0, hls, to 'C:\Users\admin\AppData\Roaming\MediaBrowser-Server\transcoding-temp\383f859adc188f58a109eda54de6a4ce.m3u8': Metadata: encoder : Lavf56.40.101 Stream #0:0: Video: h264 (libx264), yuv420p, 720x404 [SAR 404:405 DAR 16:9], q=-1--1, max. 1000 kb/s, 25 fps, 90k tbn, 25 tbc Metadata: encoder : Lavc56.49.101 libx264 Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc56.49.101 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) server-63581141399.txt transcode-951d9d9e-fd50-4bc8-ac18-3cf5ec69fd80.txt
Spaceboy 2573 Posted October 22, 2015 Posted October 22, 2015 I've been posting about this on the dvblink thread for some time 1
pünktchen 1410 Posted October 23, 2015 Posted October 23, 2015 Hi @@Luke, i've modified the MediaPortal plugin to match the language codes of Emby, but the user profile settings for audio selection isn't respected. Also there's another problem i need your help. This is from server log when i start a live tv stream with two audio streams: 2015-10-24 00:43:22.4113 Info - App: HttpClientManager GET: http://192.168.0.3:4322/MPExtended/StreamingService/json/GetMediaInfo?type=TV&itemId=TV-45-20151023224318&provider=0 2015-10-24 00:43:22.6513 Info - App: Live stream info: {"Protocol":"Http","Id":"45","Path":"http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318","Type":"Default","Container":"ts","RunTimeTicks":0,"ReadAtNativeFramerate":true,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":false,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"e2c02591b55c6b121fb0f65056883a50_45","MediaStreams":[{"Codec":"H264","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"Profile":"baseline","Type":"Video","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":40},{"Codec":"AC3","Language":"ger","IsInterlaced":false,"Channels":6,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"AC3","Language":"eng","IsInterlaced":false,"Channels":2,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":7000000,"RequiredHttpHeaders":{}} 2015-10-24 00:43:22.6713 Info - App: Profile: Unknown Profile, Path: http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2015-10-24 00:43:22.6713 Info - App: Profile: Unknown Profile, No direct play profiles found for Path: http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318 2015-10-24 00:43:22.6713 Info - HttpServer: HTTP Response 200 to 127.0.0.1. Response time: 3995.2285 ms. Url: http://127.0.0.1:8096/emby/LiveStreams/Open?UserId=7a2a359b67d44419a168df243e2b6715&StartTimeTicks=0&ItemId=8d2d103aaf4186ebe1c4102a73c9cc02&PlaySessionId=386d7a7c696a401da32b26972ae51ac9 2015-10-24 00:43:22.6973 Info - App: HttpClientManager GET: http://192.168.0.3:4322/MPExtended/TVAccessService/json/GetProgramsDetailedForChannel?channelId=98&starttime=2015-10-23T23:43:22&endtime=2015-11-06T22:43:22 2015-10-24 00:43:22.7673 Info - HttpServer: HTTP GET http://127.0.0.1:8096/emby/videos/8d2d103aaf4186ebe1c4102a73c9cc02/stream.webm?DeviceId=152c388a370467f447a35c63ac26b53c8e67843f&MediaSourceId=45&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=548251429&AudioBitrate=320000&MaxHeight=1080&ClientTime=635812370026713824&PlaySessionId=386d7a7c696a401da32b26972ae51ac9&api_key=4e83c8c2cf504eb49e169f69529ac2b2&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_e2c02591b55c6b121fb0f65056883a50_45&EnableAutoStreamCopy=false Ip: 127.0.0.1:18362. Headers: Host=127.0.0.1:8096,User-Agent=Mozilla/5.0 (Windows NT 6.1; WOW64; rv:40.0) Gecko/20100101 Firefox/40.0,Accept=video/webm,video/ogg,video/*;q=0.9,application/ogg;q=0.7,audio/*;q=0.6,*/*;q=0.5,Accept-Language=en-US,en;q=0.5,Range=bytes=0-,Connection=keep-alive 2015-10-24 00:43:22.8353 Info - App: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150918\ffmpeg.exe -fflags +genpts -async 1 -vsync -1 -re -i "http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0,scale=trunc(oh*a/2)*2:min(ih\,1080)" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 8000000 -bufsize:v (8000000*2) -b:v 8000000 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ab 320000 -af "aresample=async=1000" -y "D:\Transcoding_Temp\transcoding-temp\411177a0b23c9912f3f75732f45401ac.webm" As you can see, there are two audio streams - "ger , index 0" and "eng , index 1" But the transcoding engine sets both audio streams to "index -1" and outputs always the first audio stream. Because of this it's not possible to switch audio in the players. http://127.0.0.1:8096/emby/videos/8d2d103aaf4186ebe1c4102a73c9cc02/stream.webm?DeviceId=152c388a370467f447a35c63ac26b53c8e67843f&MediaSourceId=45&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=548251429&AudioBitrate=320000&MaxHeight=1080&ClientTime=635812370026713824&PlaySessionId=386d7a7c696a401da32b26972ae51ac9&api_key=4e83c8c2cf504eb49e169f69529ac2b2&LiveStreamId=1a755974de5dc3461dc6ecae8ddec68b_e2c02591b55c6b121fb0f65056883a50_45&EnableAutoStreamCopy=false {"Protocol":"Http","Id":"45","Path":"http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318","Type":"Default","Container":"ts","RunTimeTicks":0,"ReadAtNativeFramerate":true,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":false,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"1a755974de5dc3461dc6ecae8ddec68b_e2c02591b55c6b121fb0f65056883a50_45","MediaStreams":[{"Codec":"H264","IsInterlaced":true,"BitRate":8000000,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"Profile":"baseline","Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":40},{"Codec":"AC3","Language":"ger","IsInterlaced":false,"Channels":6,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"AC3","Language":"eng","IsInterlaced":false,"Channels":2,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":7000000,"RequiredHttpHeaders":{}} C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150918\ffmpeg.exe -fflags +genpts -async 1 -vsync -1 -re -i "http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0,scale=trunc(oh*a/2)*2:min(ih\,1080)" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 8000000 -bufsize:v (8000000*2) -b:v 8000000 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ab 320000 -af "aresample=async=1000" -y "D:\Transcoding_Temp\transcoding-temp\411177a0b23c9912f3f75732f45401ac.webm" ffmpeg version N-75410-g58fe57d Copyright (c) 2000-2015 the FFmpeg developers built with gcc 5.2.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-libvo-aacenc --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 5.100 / 6. 5.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, mpegts, from 'http://192.168.0.3:4322/MPExtended/StreamingService/stream/RetrieveStream?identifier=TV-45-20151023224318': Duration: N/A, start: 2.064878, bitrate: N/A Program 137 Stream #0:0[0x30]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt470bg), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc Stream #0:1[0x40](ger): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:2[0x41](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 384 kb/s -async is forwarded to lavfi similarly to -af aresample=async=1:min_hard_comp=0.100000:first_pts=0. [libvpx @ 0000000005b1e540] v1.4.0 Output #0, webm, to 'D:\Transcoding_Temp\transcoding-temp\411177a0b23c9912f3f75732f45401ac.webm': Metadata: encoder : Lavf57.2.100 Stream #0:0: Video: vp8 (libvpx), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=0-50, 8000 kb/s, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc57.3.100 libvpx Stream #0:1: Audio: vorbis (libvorbis), 48000 Hz, 5.1(side), fltp, 320 kb/s Metadata: encoder : Lavc57.3.100 libvorbis Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> vp8 (libvpx)) Stream #0:1 -> #0:1 (ac3 (native) -> vorbis (libvorbis)) Press [q] to stop, [?] for help What i am missing? 2
Luke 42237 Posted October 25, 2015 Posted October 25, 2015 make sure you're not reporting any duplicate stream indexes because then the server will assume you're giving bad input and set them all to -1. compare to a working video file.
pünktchen 1410 Posted October 25, 2015 Posted October 25, 2015 Ah okay, if the video stream has an index 0, the audio streams have to start with 1 and not with 0. I think i got audio switching working while direct playing on my Android tablet, but of course i can't hear any difference between stereo and ac3. When playing tv in a browser (stream gets transcoded) and i try to switch the audio streams, the playback stops with an error!
Luke 42237 Posted October 25, 2015 Posted October 25, 2015 because they need to be the exact order and that is probably the issue. if the audio stream appears first in the container, are you reflecting that in your stream indexes? i am guessing you are not. we used to probe all live tv streams for exact info but for many this wound up being too slow so we had to remove it. now we only do it for the built-in live tv. if MP interrogates the stream when it is opened, then you should tap into that information. if it does not then you are probably stuck for right now and should omit them from the media info in order to avoid errors. clients that direct play can generally get media info from the video player which can allow this to be solved client-side on a per app basis. when transcoding is used, the server needs to know up front ahead of time. it is possible for the server to collect the info after transcoding has started but that represents a fundamental shift in the api because we then have to get that information passed down to client apps after they've started playing.
pünktchen 1410 Posted October 25, 2015 Posted October 25, 2015 Thank you for your lengthy explanation! The order of stream indexes in general is correct, but MP delivers 0,1,2... for video AND 0,1,2,3... for audio. So it always starts with 0 for every stream type (subtitles also). As a workaround i count the audio indexes +1 in the plugin. That shouldn't be a problem because it doesn't change the order?!
pünktchen 1410 Posted October 25, 2015 Posted October 25, 2015 Hi @@benjamoomin i've just uploaded another version to Embys plugin catalogue, that should respect the prefered audio language settings within your Emby user profile. Unfortunatally right now you cannot switch the audio stream when Emby transcodes your live tv. This one needs further inspection by me... 1
pünktchen 1410 Posted October 26, 2015 Posted October 26, 2015 @@Luke Sorry for all my annoying questions, but i really want to get this fixed! The pre selection of the audio stream by language settings is working right now, but when i try to switch the audio stream while Emby is transcoding, playback is canceled. This also happens if i try to change the transcoding bitrate! So i really need to know what happens in detail in the background if i do something from above. Is the live tv stream closed by the transcoding engine to get restarted with other options? Are the mediainfos demanded a second time by the transcoding engine? What methodes are called by Emby the time i change the stream? (eg. public Task<MediaSourceInfo> GetChannelStream()) I'm really curious about your answer.
Luke 42237 Posted October 26, 2015 Posted October 26, 2015 yes it will end up closing and reopening the stream because we feed the url directly to ffmpeg. when ffmpeg stops the stream closes.
pünktchen 1410 Posted October 26, 2015 Posted October 26, 2015 (edited) yes it will end up closing and reopening the stream because we feed the url directly to ffmpeg. when ffmpeg stops the stream closes.Okay so either you close the stream and feed ffmpeg with the url of the previous stream without really restarting a new stream or you start a new live tv stream and it is just to fast. MP hasn't closed the previous stream while you are demanding another one -> no free tuner available! Edited October 26, 2015 by pünktchen
Luke 42237 Posted October 26, 2015 Posted October 26, 2015 Sorry I lied. Forget I said that. It only opens at the beginning.
Luke 42237 Posted October 26, 2015 Posted October 26, 2015 The get channel stream method is only called once but the video player may disconnect and reconnect using the same url
pünktchen 1410 Posted October 26, 2015 Posted October 26, 2015 Thank you! Now i have something to play with.
benjamoomin 3 Posted October 28, 2015 Author Posted October 28, 2015 Hi @@pünktchen, sorry for the delayed response, but yes the latest update now means that the English stream is always selected now instead of the NAR steam. Thanks very much! Good luck trying to get the switching between audio streams to work. As a side issue I was messing about and removed and reinstall the mediaportal plugin for emby and now I can't seemingly get the channels to sort correctly by Default (as defined by the channel group set up in the mp tv server). Regardless of the sort order I select in the emby plugin it seems to always sort by channel number. Any ideas how I can rectify this?
pünktchen 1410 Posted November 14, 2015 Posted November 14, 2015 Hi @@pünktchen, sorry for the delayed response, but yes the latest update now means that the English stream is always selected now instead of the NAR steam. Thanks very much! Good luck trying to get the switching between audio streams to work. As a side issue I was messing about and removed and reinstall the mediaportal plugin for emby and now I can't seemingly get the channels to sort correctly by Default (as defined by the channel group set up in the mp tv server). Regardless of the sort order I select in the emby plugin it seems to always sort by channel number. Any ideas how I can rectify this? Sorry for the late response! With the next plugin update you get a setting to enable channel index numbers. Probably you have to clear your browser cache to see the setting.
benjamoomin 3 Posted April 9, 2016 Author Posted April 9, 2016 Hi I'm having similar issues again where the NAR audio is being used be default instead of the ENG audio Attached are server and trancode logs. I restart the server before testing so should just have relevant logs. 13:50 trying to view channel itv2 on PC (same box as emby server) via chrome - ENG selected by default 13:53 viewing itv2 from Android app - NAR selected by default Also attached are screenshots from the browser and the app Can be a bit frustrating as I also use the Android TV app which currently won't let me change the audio track, but that's a different issue server-63595806611.txt transcode-af1210a4-4ee5-428e-8dc2-47b688052f3e.txt
pünktchen 1410 Posted April 9, 2016 Posted April 9, 2016 I can't do anything in the plugin about this. The first audio track in the stream is always set as default track - in your case it is "nar". So if you have set "english" as your prefered language and disabled "use default audio track regardless of language" in the playback settings of your user profile, it should work the way you want it to and select the "eng" track. It's seems that the Android app does not respect your user profile settings!
benjamoomin 3 Posted April 10, 2016 Author Posted April 10, 2016 Thanks @@pünktchen. I'll raise it in the android app and android tv app forums. As a thought is there any way for this plugin to change the order of audio tracks? For example always make the NAR track come last, forcing it to be stream 9 or something similar? Thanks
Spaceboy 2573 Posted April 10, 2016 Posted April 10, 2016 (edited) Having similar problems still with Dvblink and the android app. Not getting any help unfortunately Edited April 10, 2016 by Spaceboy 1
