fc7 123 Posted October 21, 2015 Posted October 21, 2015 In my music library, multi-disc albums are not detected correctly. Meaning that all the songs from both discs are showed under the same disc so on the same album I end up with two tracks number 1, two tracks number 2, etc, as you can see in the attached screenshot. Moreover, even when each disc folder has the correct artwork files, Emby is not showing any artwork at all. I'm running Emby server 3.0.5724.6 (latest stable version) on CentOS 7. I double checked that I'm following the correct naming guidance from Emby's website (example folder organization attached in a screenshot). I can upload a library scanning log if needed but I didn't see any errors at all. Thanks.
Solution Luke 42243 Posted October 21, 2015 Solution Posted October 21, 2015 make sure the files are tagged with the disc number 1
Luke 42243 Posted October 21, 2015 Posted October 21, 2015 http://emby.media/community/index.php?/topic/26385-multi-disc-track-sort-not-working-for-flac-files/
fc7 123 Posted October 21, 2015 Author Posted October 21, 2015 That will be the most probable cause. I will check and come back. Thanks a lot Luke. Sent from my iPhone using Tapatalk
fc7 123 Posted October 21, 2015 Author Posted October 21, 2015 (edited) Confirmed. The problem was the missing "Discnumber" tag. After adding it now the songs are grouped correctly. I'm still having problems with the album name and the artwork (still missing but the artwork is present in each disc subfolder) that I will check that later. @Luke: maybe you want to add to the wiki in Emby site that for multi-disc albums having the songs tagged with the proper discnumber tag is a must in order for Emby to add them to the library correctly since this tag doesn't seem to be a well known one. This can prevent further questions like this in the future. Thanks. Edited October 21, 2015 by fc7
fc7 123 Posted October 22, 2015 Author Posted October 22, 2015 Is it normal that after adding the discnumber tag and refreshing the album now the album name is equal to the string in the album tag of the first CD in a multi-disc set? Using the same example as in the picture above, I would expect that after refresh the album name will be just "The Lamb Lies Down on Broadway" and include both discs. But in reality the album name is "The Lamb Lies Down on Broadway Disc 1" and includes both discs. I can see the same happening with several other multi-disc albums that I have in my library and that I added the discnumber tab to them. They are correctly grouped under the same album but the album name is equal to the first CD in the set and not just the album name.
