siddhartha 11 Posted October 20, 2015 Posted October 20, 2015 I'm running emby beta 3.0.5768.4 and iOS 7.1.2. When I click on the DLNA link to Play To my TV, I'm present with a list of DLNA options. I can no longer simply click on an option and it will set it. When I click on an item (e.g. My Device), the text will bold, but the popup window will stay open. I need to first tap the item, then hold my finger down on the item until it highlights blue as though the text is highlighted. Once it is, I then need to tap the item again. The dialog box will go away and the option will be properly set. This behaviour is not in the latest official release. Also, my Movie and TV collections are completely empty. I cannot see any Suggestions, or Shows, or a list of movies. This behaviour is also not in the latest official release. Unfortunately, I cannot use the latest official release because my AAC encoded MKV files have extremely buggy audio and I cannot pause any movies. This is fixed in the latest beta, however. Thanks!
siddhartha 11 Posted October 20, 2015 Author Posted October 20, 2015 By moving and refreshing my metadata folder, I am able to see my library again. The issue with selecting popup menu items remains. I found I can duplicate the bug in Chrome for Windows if I press F12 then set my device to Apple iPhone 5. Go up to the DLNA icon, and when you select a device, it will not close the popup window nor set the device.
siddhartha 11 Posted October 21, 2015 Author Posted October 21, 2015 It looks like only the first page of my library appears on Safari iOS. Setting any filters, sorting, or changing pages makes the content disappear. There is also a large amount of whitespace between the top navbar and the movie posters. This behaviour is the same for Chrome on iOS. I have done a clean install of emby server and have no custom css branding.
Luke 42243 Posted October 21, 2015 Posted October 21, 2015 On ios chrome is the same thing as safari. To be honest I'm not really sure what we can do here. These symptoms do not appear on ios8 and ios9. The web client is moving fast adopting new technologies and its not always easy to support older browser versions.
siddhartha 11 Posted October 21, 2015 Author Posted October 21, 2015 Is there an archive of older beta binaries?
siddhartha 11 Posted October 21, 2015 Author Posted October 21, 2015 Also, since I can duplicate the menu bug in the latest Chrome for Windows using the F12 device preview, I wonder if there isn't a bug on newer browsers.
siddhartha 11 Posted October 21, 2015 Author Posted October 21, 2015 (edited) I did a build of 3.0.5724.5 in VS and all is well. I'll just hold out for an iOS app and cross my fingers it's 7.1.2 compatible. Edited October 21, 2015 by siddhartha
mediacowboy 438 Posted October 21, 2015 Posted October 21, 2015 Luke will be able to answer for sure but I believe the new iOS app will only be compatible with 8.1 and up
Luke 42243 Posted October 21, 2015 Posted October 21, 2015 Yes, 8.1 it is. As of two days ago, the numbers on the apple developer portal show 61% of devices are already upgraded to ios9 and 91% are running ios8 or greater.
