mgarman 3 Posted December 3, 2013 Posted December 3, 2013 Hii, Does anyone know how to reset Genre Cleaner back to Default as if it was installed the first time. Thanks mgarman
Solution ebr 16342 Posted December 3, 2013 Solution Posted December 3, 2013 You can delete the GenreCleaner.xml file in the configurations folder under plug-ins. However, keep in mind that GenereCleaner modifies your metadata - including the xml files if you are saving those locally. So simply re-setting it won't necessarily bring back all the old genres.
mgarman 3 Posted December 4, 2013 Author Posted December 4, 2013 (edited) Thanks. Followup question. What about Music, flac and mp3s? does it modify the genre tags within the files? Edited December 4, 2013 by mgarman
Tikuf 663 Posted December 4, 2013 Posted December 4, 2013 Thanks. Followup question. What about Music, flac and mp3s? does it modify the genre tags within the files? No. Your files should are left untouched. 1
