wraslor 70 Posted October 19, 2015 Posted October 19, 2015 Web client is no longer remembering quality settings and defaults to 4mbps for every item. Sent from my iPhone using Tapatalk
Luke 42289 Posted October 19, 2015 Posted October 19, 2015 No, we have created a new default, but the new default is Auto. It is recommended you leave it at auto for best performance because it perform bandwidth tests with the server to find the ideal rate.
wraslor 70 Posted October 19, 2015 Author Posted October 19, 2015 is there a way to change that? I have a 5 up connection and several people streaming at different times, if 2 jump on at the same time it chokes. Sent from my iPhone using Tapatalk
Luke 42289 Posted October 19, 2015 Posted October 19, 2015 of course, the same way as always. that just happens to be the new default value. it is still there in client-side settings, and as soon as they change it in the video player it also saves it. additionally there is server-side control under playback -> streaming to apply a global limit. so you could cap everyone at say, 1mbps no matter what their in-app setting is.
wraslor 70 Posted October 19, 2015 Author Posted October 19, 2015 Ok when I change it in the web player it reverts back for example I bump down to 1 meg for a tv show play next ep and its back to 4. But if I understand you right I can set the global to 1 and that's per device? Not total pool correct? Thanks Sent from my iPhone using Tapatalk
Luke 42289 Posted October 19, 2015 Posted October 19, 2015 yes, correct. i can confrm changing in the video player is not sticking so i will fix that. changing in app settings though does stick.
wraslor 70 Posted November 4, 2015 Author Posted November 4, 2015 Any updates on this? still changing every time on me Sent from my iPhone using Tapatalk
Luke 42289 Posted November 4, 2015 Posted November 4, 2015 yes i decided to not have the video player be a permanent setting. just change it in app settings if you want a permanent change.
