Guy 7 Posted October 19, 2015 Posted October 19, 2015 (edited) Note: test environment is nfo files do not exist yet only xmls. Goal: Creat nfo files for all TV shows including seasons and episodes by batch instead of one by one Works: Running metadata editor refresh for movies creates the nfo files. [issue] Running metadata editor refresh for TV Series at the parent folder only creates a tvshow.nfo not seasons or episodes Running metadata editor refresh for TV series at the series level does create the necessary nfo files for seasons and episodes Edited October 19, 2015 by Guy
Happy2Play 9811 Posted October 19, 2015 Posted October 19, 2015 Please post your log, this will show your setting. Have you verify your settings in Metadata-Services
Guy 7 Posted October 19, 2015 Author Posted October 19, 2015 Settings This is the log when refreshing at the library level which produces no NFO files for Seasons or Episodes server-63580853873 - Top-Level-Refresh.txt This is the log when refreshing at the series level and works fine. NFO files for seasons and episodes are created server-63580853873-Series-Level-Refresh.txt
