Happy2Play 9814 Posted October 18, 2015 Posted October 18, 2015 CovertArt won't treat Primary images only thumb. Have to delete primary to get treated thumb. But Primary image does get recreated if one is not present so you end up with untreated image again. Or is this a server issue wanting to present Primary image instead of Thumb?
Luke 42252 Posted October 18, 2015 Posted October 18, 2015 for top level folders we've always displayed primary first, then fallback to thumb.
Happy2Play 9814 Posted October 18, 2015 Author Posted October 18, 2015 (edited) How do you get same treatment for My Media with image disconnect ? When different images get treated differently. Example of issue Home - Edit Image Only one image treated Metadata Manager Both images treated Edited October 18, 2015 by Happy2Play
ebr 16342 Posted October 19, 2015 Posted October 19, 2015 Those collage "slice" images are not created by CA. They are created by the server core and, I think, they completely bypass CA treatment (but I'm not sure about that).
Xzener 729 Posted October 19, 2015 Posted October 19, 2015 You could use Snipping Tool to capture the "Slice" image... The add it as a new primary. CA should be able to treat it then yes?
Happy2Play 9814 Posted October 19, 2015 Author Posted October 19, 2015 "Treat User Views like media folders" update resolved my issue. v4.0.9.1 1
ebr 16342 Posted October 19, 2015 Posted October 19, 2015 "Treat User Views like media folders" update resolved my issue. v4.0.9.1 Good. I'm sure it will create unwanted or at least unexpected behaviors for some others who may have been depending on these items getting bypassed by CA but it works more correctly now.
