yardameus 221 Posted October 17, 2015 Posted October 17, 2015 (edited) Version 3.0.5768.1 Just noticed today that after adding several movies, the images were not being downloaded. The backdrop was, but nothing else was, and these were all movies with plenty of images to choose from for every category. I was able to manually pick all of the images, they were just not automatically downloaded like usual. server-63580679438.txt Edited October 17, 2015 by yardameus
Ultroman 88 Posted October 17, 2015 Posted October 17, 2015 I am experiencing something similar. All the images were gone after I updated yesterday, except for a few of the series I watch the most. Then I enabled all the "Automatically update from ***"-options in the Metadata => Advanced tab, and did a full library scan. Most of my shows and movies now have images, but about 40% are missing their primary image. ALL of them had all their images two days ago, because I've painstakingly found images for them online manually. But now it seems that 3 times as many of the primary images are screwed up, than were screwed up when I started out. What's the deal? Where did all those images go? Are they now taking up space in the Metadata-folder and not linked to anything? Or does the server clear out the unused images from the folder? Before you ask, I have NOT ticked the "Save artwork and metadata into media folders", as I hate crowded folders.
yardameus 221 Posted October 17, 2015 Author Posted October 17, 2015 I have not had any issues with existing images being messed up, but I've had artwork downloaded all along.
Ultroman 88 Posted October 17, 2015 Posted October 17, 2015 Oh well, I guess I'll start my own issue, then.
yardameus 221 Posted October 18, 2015 Author Posted October 18, 2015 Adding a new series also has the same result. No images downloaded. Is this related to an issue with TMDB or TVDB?
yardameus 221 Posted October 18, 2015 Author Posted October 18, 2015 Should I upload another one? I don't really know what to look for in the log.
Happy2Play 9800 Posted October 18, 2015 Posted October 18, 2015 I would since you added something new and it is still doing the same thing.
Koleckai Silvestri 1154 Posted October 18, 2015 Posted October 18, 2015 (edited) Had the same problem earlier as well. I had to download them manually through the Edit Images tool. Not exactly sure what time and have restarted the server about 30 times today so don't know which log file it is. Will probably add more content tomorrow. Edited October 18, 2015 by Koleckai Silvestri
yardameus 221 Posted October 18, 2015 Author Posted October 18, 2015 server-63580679438.txt Here's another log.
Luke 42185 Posted October 18, 2015 Posted October 18, 2015 tmdb has a lookup by imdb which we are using but it comes up not found because they don't have the imdb on file for that particular title. i guess we will have to adjust to that situation.
Ultroman 88 Posted November 2, 2015 Posted November 2, 2015 (edited) Just wanted to say, that I am experiencing the same in alarming amounts. A lot of 404s from tmdb. Edited November 2, 2015 by Ultroman
yardameus 221 Posted November 2, 2015 Author Posted November 2, 2015 Mine seems to have worked itself out. I almost wonder if it's just issues on their end (image providers).
dejavux2 47 Posted November 3, 2015 Posted November 3, 2015 I'm having the same issue with images for newly added content.
Ultroman 88 Posted November 3, 2015 Posted November 3, 2015 I'm having the same issue with images for newly added content.Try to go to the affected title and click Refresh. Suddenly that worked for all my broken titles. Must be something in the newest server update or something, because I could swear it didn't work a few days ago. Godspeed
dejavux2 47 Posted November 9, 2015 Posted November 9, 2015 My issue seems to be mainly for 'backdrop' images. If I go to the affected title, click 'Save', then click 'Refresh', it will download 1 more backdrop. I have the Number of Backdrops set to 40 to get the most backdrops. So, say I have 3 backdrops now for a certain title. I go into Metadata Manager, scroll to that title, click 'Save', then click 'Refresh', it will download 1 more backdrop....brining me to 4 for that title. If I click on the button to view/download backdrops, I can see that there are at least 12 available, but it will only do one at a time using the method mentioned above. I am on Server Dev Version 3.0.5790.100 server-63582541776.txt
djlf 40 Posted November 10, 2015 Posted November 10, 2015 Same issue here for new added content. Will only download one backdrop even though ive set it to 3. Have to manually download rest and at that its inconsistent, This update is really buggy. Populating screens is also slower in some areaa.
