speedingcheetah 39 Posted October 14, 2015 Posted October 14, 2015 The guide just stopped showing up entirely. Just loads a blank page now in an browser. Android app loads Guide, but it is extremely slow. I restarted the server, even rebooted the computer. I ran the scheduled tasks to refresh library and guide....nothing. log attached Log.txt
Luke 42185 Posted October 14, 2015 Posted October 14, 2015 go into live tv setup and double check that the tuner ip address is correct.
speedingcheetah 39 Posted October 17, 2015 Author Posted October 17, 2015 (edited) go into live tv setup and double check that the tuner ip address is correct. It shows up fine and available. It is set to static and does not change. I fixed the issues mentioned in post by resetting the Guide Source....Schedule Direct. That worked...until now. Today, Now the guide page loads the channels...but has not guide info. Also, Emby does not seem to be accepting Schedules Direct listing info. I type in zip code....but it does not populate anything under the lineup dropdown menu. Edited October 17, 2015 by speedingcheetah
Luke 42185 Posted October 17, 2015 Posted October 17, 2015 It shows up fine and available. It is set to static and does not change. I fixed the issues mentioned in post by resetting the Guide Source....Schedule Direct. That worked...until now. Today, Now the guide page loads the channels...but has not guide info. Also, Emby does not seem to be accepting Schedules Direct listing info. I type in zip code....but it does not populate anything under the lineup dropdown menu. Please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
speedingcheetah 39 Posted October 17, 2015 Author Posted October 17, 2015 (edited) Please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ I already did that...that is why i am posting here...again......i just checked my logs... 2015-10-16 20:30:01.1821 Error - HttpServer: Error processing request for /LiveTv/ListingProviders/Lineups?Id=1e689e6421b141cc8c6d133c70ecddb7&Location=55426&Country=USA *** Error Report *** "The remote server returned an error: (400) Bad Request."\ Lol...I updated the post with log file....funny though..only 1 channel now has guide info....weird. Log2.txt Edited October 17, 2015 by speedingcheetah
Luke 42185 Posted October 17, 2015 Posted October 17, 2015 schedules direct is returning an error that indicates there's a problem with your account. unfortunately i can't tell you more because the version of emby server you're running doesn't log it, but that's the gist of it. you can try removing your schedules direct info and adding it back. if that still doesn't work send a PM to rkulagow and ask him to look at your account. in the future emby server will make the information of what's wrong more visible to you.
speedingcheetah 39 Posted October 17, 2015 Author Posted October 17, 2015 (edited) schedules direct is returning an error that indicates there's a problem with your account. unfortunately i can't tell you more because the version of emby server you're running doesn't log it, but that's the gist of it. you can try removing your schedules direct info and adding it back. if that still doesn't work send a PM to rkulagow and ask him to look at your account. in the future emby server will make the information of what's wrong more visible to you. Current version??? Arnt I running the most recent version? Its set to auto update and says is up to date, There is nothing wrong with my Schedule direct account...i can log into it just fine. Yes,...i tried deleting the setting in Emby and re-adding it. same error. Also deleted and added new schedule in Schedules direct account. It was working fine last night. I got back from work today and this.....Nothing on my end has changed. Edited October 17, 2015 by speedingcheetah
Happy2Play 9800 Posted October 17, 2015 Posted October 17, 2015 (edited) I think he means the next release shows more logging. Edited October 17, 2015 by Happy2Play
speedingcheetah 39 Posted October 17, 2015 Author Posted October 17, 2015 (edited) I think he means the next release shows more logging. Actually...i just updated to the beta. Nope still same issue.... More logs very long Log3.txt Edited October 17, 2015 by speedingcheetah
