gator99 5 Posted October 14, 2015 Posted October 14, 2015 Anyone else try the new Chromecast Audio? I tried with the latest Android emby app and while playing music it wouldn't connect, though it will trough my regular Chromecasts? Sent from my Nexus 5 using Tapatalk 1
Luke 42242 Posted October 21, 2015 Posted October 21, 2015 if i had to guess it's because our chromecast receiver app is assuming the CC receiver is video-capable. So that's probably what will need to be corrected. I will try to look at it soon, tho all are welcome to get a head start on it: https://github.com/MediaBrowser/Emby.Chromecast
Luke 42242 Posted October 23, 2015 Posted October 23, 2015 I've pushed an update to our chromecast receiver. please test again by power cycling your chromecast device. thanks.
IanDury 0 Posted October 24, 2015 Posted October 24, 2015 Thanks! Works fine now. Minor issue, shutdown the app on the remote device (stop casting) doesn't work.
gator99 5 Posted October 31, 2015 Author Posted October 31, 2015 Still no luck with nexus 6 on Android 6.0 with EMBY 3.0.5781.0 Sent from my Nexus 6 using Tapatalk
Luke 42242 Posted October 31, 2015 Posted October 31, 2015 Still no luck with nexus 6 on Android 6.0 with EMBY 3.0.5781.0 Sent from my Nexus 6 using Tapatalk Please be more descriptive. It has tested fine for others.
gator99 5 Posted October 31, 2015 Author Posted October 31, 2015 Sorry, everytime I try to connect nothing happens, try with Pandora or tunedin and the audio conects immediately. When I connect EMBY with my regular Chromecast it connects immediately. Sent from my Nexus 6 using Tapatalk
gator99 5 Posted October 31, 2015 Author Posted October 31, 2015 Disregard, I finally got it to connect, went into apps remote control then connected to Chromecast audio, now it is connecting. Sent from my Nexus 6 using Tapatalk
