Cerothen 98 Posted October 12, 2015 Posted October 12, 2015 Good Morning All, I would like to report a bug related to (I think) the android app. if you look in the below images the web site when accessed via android chrome works as expected however the app "Emby for Android" reports that there is an ssl error. If you just hit ok and proceed you can log in however you can't see any images or watch any content is there a suggested resolution? I use the same certificate on the emby server as I do on my typical webserver.
Luke 42243 Posted October 12, 2015 Posted October 12, 2015 we still have some work to do with ssl on android.
Cerothen 98 Posted October 12, 2015 Author Posted October 12, 2015 Thanks for the update and as always love all the attention you guys put into this. Let me know if there is anything I can provide to you to help out.
vick1982 15 Posted November 14, 2015 Posted November 14, 2015 (edited) is there any timeline when the android app will work with https with self signed ? i can just hit continue on the ssl error and everything loads and all the movies and shows are visible.. but when trying to play a video then it has " playback error" Edited November 23, 2015 by vick1982
Cerothen 98 Posted November 24, 2015 Author Posted November 24, 2015 The certificate I was using was not self signed and was issued by DigiCert but I still had the same issue. I think it was due to the certificate from Digicert needing an intermediate certificate as well. I employed the solution specified here: http://emby.media/community/index.php?/topic/23633-cannot-connect-over-https-wan/?p=237387 And I am able to connect over https through my nginx proxy just fine now the only difference is that the nginx proxy has the intermediate certificate specified.
