e123enitan 276 Posted October 13, 2015 Author Posted October 13, 2015 A fix for this will be in the next release. It will not crash the sync, but instead will skip adding the episode. Afterwards, if you find that the season is missing in Kodi, you can go into the metadata manager, add the number to the season, press save and it will update the entry in Kodi right away. There is no need to do a full resync to correct this discrepancy. Thanks for the efforts and heads up, I shall look out for the next release hopefully the issue will not recur. Cheers!
Angelblue05 4132 Posted October 13, 2015 Posted October 13, 2015 The fix is in 1.1.48 which has been released for a few hours now. 1
e123enitan 276 Posted October 13, 2015 Author Posted October 13, 2015 (edited) The fix is in 1.1.48 which has been released for a few hours now. Nice- I shall test drive tonight and post issue if any, awesome and what a responsive fixed time Edited October 13, 2015 by e123enitan 1
e123enitan 276 Posted October 14, 2015 Author Posted October 14, 2015 Nice- I shall test drive tonight and post issue if any, awesome and what a responsive fixed time As promised here is the update, first based on the discovery of inconsistency in the episodes #'s, I went to rebuild my server, which seems to have correted the nuance on the server side, In addition, the changes you make to addon it seems to have resolved the initial issue "break of Sync, every is perfect. I have attached logs for your review, Thanks in a million http://xbmclogs.com/p0kaereaa http://xbmclogs.com/pcfwr42qh 1
