foghat 65 Posted October 10, 2015 Posted October 10, 2015 Noticed in the config options when viewing all movies there is option to set the view for smart view (default) or grid view. I could not see any difference between these views - what is the difference?
ebr 16336 Posted October 11, 2015 Posted October 11, 2015 You are in the grid view when you selected that option. The smart view was the one you came from to get there (that showed you latest, next up, etc.). That option determines whether you want to go to that smart view for that library or just go directly to the grid and bypass the smart view.
