Ceth 3 Posted October 10, 2015 Posted October 10, 2015 I think this is a known issue, but it is impossible to seek within a recorded program. I am using a WMC backend with serverwmc and Ceton tuners. It doesn't matter what client I use, you can't seek or skip to anywhere in the program. After they are converted by mcebuddy, seek works, but trying to seek while transcoding a WTV file doesn't.
Luke 42241 Posted October 10, 2015 Posted October 10, 2015 it's probably ffmpeg's problem, which in turn unfortunately becomes our problem.
Ceth 3 Posted October 29, 2015 Author Posted October 29, 2015 This seems to be fixed with 3.0.5768.7, the Fire TV app 1.1.19a (beta), or the combination of both. Good work, whatever you did! 1
Nathanio 35 Posted October 29, 2015 Posted October 29, 2015 I found that it won't seek until it has all the media information (i.e. scanned it and done a proper refresh with metadata). A quick refresh by the web browser and it seeks just fine then
