AKSkinz 10 Posted October 10, 2015 Posted October 10, 2015 Just setup a HDHomerun Extend in Emby but it won't download any guide data when set to QAM for my provider (FIOS). I went through the setup of the device and had it scan for channels (found 30+). If I set it to Antenna, it looks like it's going through the downloading of data but when set to QAM (which is what I'm using) it takes less then 1 sec to complete and no data is downloaded or shown in the guide. When I had it set to Antenna it did download the channel icons and populated them so it downloaded something. I am running the current beta and also tried the dev build but no change. server-63580016986.txt
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 Which lineup are you using at Schedules Direct?
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 Leominster, US Verizon Fios Burlington - Digital CableDigital
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 I need your postal code, or the specific USA-{whatever}-QAM that you're retrieving, since your name on the forum may not be the name you've registered with on the Schedules Direct website. You can send it as a private message if you'd like.
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 Worked with Rob but he said it's pulling the data so it must be a client side issue. Here is the current log files for the last scan. server-63580032000.txt server-63580077913.txt
Luke 42241 Posted October 10, 2015 Posted October 10, 2015 yea the channels in the tuner are not matching the data from SD App: Found channel: 1 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 2 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 3 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 4 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 5 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 6 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 7 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 8 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 9 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 10 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 11 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 12 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 13 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 14 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 15 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 16 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 17 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 18 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 19 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 20 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 21 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 22 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 23 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 24 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 25 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 26 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 27 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 28 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 29 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 30 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 31 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 32 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 33 in Schedules Direct 2015-10-10 12:41:03.1467 Debug - App: Found channel: 34 in Schedules Direct 2015-10-10 12:41:03.1467 Info - App: Added 34 channels to the dictionary 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 2.1 WGBH HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 2.2 GBH Wor 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 4.1 WBZ-TV 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 4.2 WBZ DEC 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 5.1 WCVB HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 5.2 Me TV 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 7.1 WHDH HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 7.2 This TV 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 9.1 WMUR 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 11.1 WENH HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 25.1 WFXT HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 25.2 WFXT Mo 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 25.3 LAFF 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 27.1 WUNI HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 27.2 LA TV 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 36.1 WSBE HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 38.1 WSBK HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 44.1 WGBX HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 44.3 GBH Cre 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 44.4 GBH Kid 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 50.1 WBIN HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 50.2 WBIN Cl 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 56.1 WLVI HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 56.2 ZUUS 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 60.1 WNEU HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 60.2 WNEU-Ex 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 62.1 WMFP HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 66.1 WUTF HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 66.2 Bounce 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 66.3 WUTF ge 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 66.4 Escape 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 68.1 WBPX HD 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 68.2 qubo 2015-10-10 12:41:03.1467 Info - App: Schedules Direct doesnt have data for channel: 68.3 ION Lif so either the wrong lineup was chosen, or unfortunately, you might just have to wait until we have a way for you to map the channels manually.
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 Actually the listings that SD is supplying for the zip code/provider is incorrect and probably should be corrected on that side. SD is just repeating the full listing from Digital as QAM where in reality it's actually should be mapped to OTA type data I would think.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 Sorry, I'm not parsing that sentence. The QAM lineup on the server has 34 channels in it. The digital lineup has a few hundred, so I'm not sure why you're saying that we're repeating the full listing of digital (aka "-X") to -QAM? The map for the -QAM looks like this: { "map": [ { "stationID": "28055", "channel": "001", "providerCallsign": "WGBH HD", "logicalChannelNumber": "2.1", "channelMajor": "2", "channelMinor": "1", "matchType": "pCallsign" }, { "stationID": "36037", "channel": "002", "providerCallsign": "GBH Wor", "logicalChannelNumber": "2.2", "channelMajor": "2", "channelMinor": "2", "matchType": "pCallsign" }, So there are other fields that Emby can use to match channels.
Luke 42241 Posted October 10, 2015 Posted October 10, 2015 Sorry, I'm not parsing that sentence. The QAM lineup on the server has 34 channels in it. The digital lineup has a few hundred, so I'm not sure why you're saying that we're repeating the full listing of digital (aka "-X") to -QAM? The map for the -QAM looks like this: { "map": [ { "stationID": "28055", "channel": "001", "providerCallsign": "WGBH HD", "logicalChannelNumber": "2.1", "channelMajor": "2", "channelMinor": "1", "matchType": "pCallsign" }, { "stationID": "36037", "channel": "002", "providerCallsign": "GBH Wor", "logicalChannelNumber": "2.2", "channelMajor": "2", "channelMinor": "2", "matchType": "pCallsign" }, So there are other fields that Emby can use to match channels. i guess we can match call sign to the guide name from hdhr?
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 I'm referring to what I see when I edit the lineup on the SD website. It shows the lineup starting at channel 2 up to the 1800 Music channels. I would think it should be more like the Broadcast lineup as that's what it more closely matches (I.E. 2.1, 2.2, 4.1, 4.2 ETC.) as that is what FIOS is offering.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 i guess we can match call sign to the guide name from hdhr? Yes - those names come from the lineups.json channel scan.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 I'm referring to what I see when I edit the lineup on the SD website. It shows the lineup starting at channel 2 up to the 1800 Music channels. I would think it should be more like the Broadcast lineup as that's what it more closely matches (I.E. 2.1, 2.2, 4.1, 4.2 ETC.) as that is what FIOS is offering. The website is for the old XML service; everything with the JSON service (which is what Emby is using) is done through client (Emby) -> Server API.
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 Why then do I need to choose a lineup on the website for it to function? There isn't an QAM lineup that I could choose, only the Digital.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 You don't need to select a lineup on the website - again, that's just for the old XML service. Once you've created your account that's the last time you'll be doing anything on the website for the JSON service (unless you're opening a trouble ticket or renewing your account).
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 I was going to try to switch to an Antenna to at least see if it works but now it's not showing any available lineups.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 You already have an antenna lineup on your JSON account. Actually, you already have 4 lineups, so you're not going to be able to add any new ones until you delete some of the existing ones first.
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 I had 2 (1 ANT, 1 FIOS) but removed them after you said I didn't need them.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 You need to use Emby for lineup management, not the Schedules Direct website. Does Emby now have a "Delete" function (it didn't yet as far as I know)? Because on the JSON server you still have 4 lineups; 2 Comcast, an Antenna, and the QAM.
AKSkinz 10 Posted October 10, 2015 Author Posted October 10, 2015 There is a delete button... I will try to delete everything and set it up again when I get home later tonight.
Luke 42241 Posted October 10, 2015 Posted October 10, 2015 well you can delete from emby but there is no option as of yet to delete from your SD account
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 OK, so the delete is a local delete and isn't doing this yet? https://github.com/SchedulesDirect/JSON-Service/wiki/API-20141201#delete-a-lineup-from-a-users-account
Luke 42241 Posted October 10, 2015 Posted October 10, 2015 correct. if you're saying it should do both then that is fine. i can add that.
rkulagow 19 Posted October 10, 2015 Posted October 10, 2015 Yes; since users are limited in the number of lineups they can have, your delete function needs to perform a local delete and send the delete API command as well.
