theMikeD 0 Posted December 2, 2013 Posted December 2, 2013 Hi there, Just upgraded to the latest version and one thing I can't figure out is how to get MB to go to the first unwatched episode of a series. For example, lets say that I'm on episode 5 of season three of Mad Men. In version 2, it would work like this: select Mad Men (MM): MM open with season 3 selected hit Enter: season 3 opens and episode 5 is selected With version three, that is no longer happening; I have to manually select everything. Is this a setting I have overlooked somewhere?
Solution Deihmos 170 Posted December 2, 2013 Solution Posted December 2, 2013 (edited) What theme are you using? It works fine for me with some themes. It does not work with Roc. There is an option to enable it in the configuration. Edited December 2, 2013 by Deihmos 1
theMikeD 0 Posted December 2, 2013 Author Posted December 2, 2013 I'm using the default theme. Looks just like the v2 theme except for small cosmetic changes. Where is the option? For the life of me I can't find it.
theMikeD 0 Posted December 2, 2013 Author Posted December 2, 2013 Ahh, found it. I can't believe I missed that! Oy, sorry.
