Nathanio 35 Posted October 9, 2015 Posted October 9, 2015 (edited) Running server version 3.0.5724.6 and when showing in Chrome Version 46.0.2490.52 beta-m (64-bit) I don't get the horizontal navigation bar in LiveTV guide. Works fine in Edge though. Both are on a Windows 10 laptop. Image attached. Edited October 9, 2015 by Nathanio
Luke 42240 Posted October 9, 2015 Posted October 9, 2015 on touch devices the scroll bar is not displayed. i'm guessing you have a touch in put device which is causing that to happen
Nathanio 35 Posted October 9, 2015 Author Posted October 9, 2015 Hi Luke, Just a standard laptop. No touch screen interface. Could it be the touch pad?
Solution bluemonkey07 590 Posted October 9, 2015 Solution Posted October 9, 2015 maybe try this http://emby.media/community/index.php?/topic/24530-mouse-over-pop-ups-on-chrome/&do=findComment&comment=240667 1
Luke 42240 Posted October 9, 2015 Posted October 9, 2015 Hi Luke, Just a standard laptop. No touch screen interface. Could it be the touch pad? yes
Nathanio 35 Posted October 9, 2015 Author Posted October 9, 2015 Thanks vidman that worked a treat. Annoyingly the trackpad driver is rather simple and doesn't actually allow me to configure anything and so doesn't allow horizontal scrolling.
