Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 In your case, I would say wait and see. I'm still searching for possible reasons. from the looks of your last log, your server seems to be sending those message all the time. I can't explain it, because I do not have this issue. Very odd.
riffy 32 Posted November 4, 2015 Posted November 4, 2015 Nope... still doing it. :-( Think I'm feed up with it now too. Going to completely remove emby server & reinstall it, again. Find all the nfo & xml files & delete them too. Start over from scratch. kodi.log
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 Boo, ok. I'm not giving up. Before you do start from scratch, can you grab the server log from that same Kodi log timeframe?
riffy 32 Posted November 4, 2015 Posted November 4, 2015 (edited) DOH! Let me see if I can catch it LOL EDIT: Snagged it before it was deleted. :-) I think that's the whole day or maybe 2 days worth of logs. server-63582105599.zip Edited November 4, 2015 by riffy 1
riffy 32 Posted November 4, 2015 Posted November 4, 2015 Wiped it all! weeeeee..... I didn't touch nothing!! I only added my library, set up auto organize & installed nextpvr & trakt plugins. Deleted the database & thumb folders in Kodi & still using the latest version you posted before for emby. *crosses fingers* 1
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 (edited) You can check your kodi log while it's running, do you see tons of messages like this (MessageType: UserDataChanged)? If not, that's good. 19:48:21 T:29656 NOTICE: EMBY WebSocketThread -> Message: {"MessageType":"UserDataChanged","Data":{"UserId":"fcbdddb4c1894b17b4760310ba2e6e3d","UserDataList":[{"PlaybackPositionTicks":0,"PlayCount":0,"IsFavorite":false,"Played":false,"ItemId":"ddada3bd58462ddaea05aee07e668994"},{"PlayedPercentage":22.031327391688,"UnplayedItemCount":315,"PlaybackPositionTicks":0,"PlayCount":0,"IsFavorite":false,"Played":false,"Key":"2e257401-5bb8-8a22-a039-32d6194cfa03","ItemId":"2e2574015bb88a22a03932d6194cfa03"}]}} Edited November 4, 2015 by Angelblue05
riffy 32 Posted November 4, 2015 Posted November 4, 2015 (edited) uhmmm.... maybe LOL It's still finding all my stuff server side tho. EDIT: No I guess that's different than what's in this log. kodi.log Edited November 4, 2015 by riffy
riffy 32 Posted November 4, 2015 Posted November 4, 2015 After all that it still stops syncing. I didn't put in music, music vids or pictures back into my library, just to keep it more simple till this is figured out. *tin foil hat* I noticed it stopped right after auto organize ran tho, cuz 2 shows I had to change the name & sorted name on. After it ran nothing else was ever added into kodi's data base. kodi.log
riffy 32 Posted November 4, 2015 Posted November 4, 2015 and as soon as I restarted kodi... back to the logs with all those updates again. kodi.log
riffy 32 Posted November 4, 2015 Posted November 4, 2015 (edited) OK all that updating goes away if I remove 3 of my folders that is full of stuff Emby-Server will never be able to figure out what it is that I had set to "Movies". I seem to have issues with this a lot for not falling into the simple & straightforward Movies or TV Show thing. I have no other way to get it into Kodi from Emby without setting it to Movies tho. My 3 crazy folders are below. Seems emby-server is constantly trying to figure out what they are & needs to get over it! :-p With them set to "Home Videos" it scans my library so much faster! But no way to see them in Kodi from Emby. :-( Other: Nature shows, news shows, really really random stuff (like: caligula.1400.days.of.terror.720p.hdtv.x264-w4f, Ch4.Unreported.World.2015.Chinas.Gay.Shock.Therapy.720p.HDTV.x264, click.uk.2015.10.31.720p.hdtv.x264-c4tv, etc...) It isn't ever going to figure them out. Pilots: Pilots of shows in the last 90 days Recorded News Shows: Local news that's recorded EDIT: Not that any of that helps with the sync stopping. LOL Edited November 4, 2015 by riffy
riffy 32 Posted November 4, 2015 Posted November 4, 2015 I am having a problem where any items that fails lookup at themoviedb.org is getting marked as updated on every server scan. I am not sure it this is related, but check to see if the items it is updating are also failing themoviedb lookup. Would that be the same thing as I described above?
xnappo 1611 Posted November 4, 2015 Posted November 4, 2015 Yes @@riffy. I don't know if it always did this @@Angelblue05 - but unmatched items always show up in the changed list now - so it is important to reduce these. I *think* if you go into the metadata and 'lock' it it prevents this from happening. xnappo
riffy 32 Posted November 4, 2015 Posted November 4, 2015 OK... well it still stopped syncing during the night. It did a lot of changes when it updated people like in that other thread. Actually it's still freak'n updating people. :-o Problem is... I have to many new items in those folders every day to be locking them all the time. Unless I can just lock the top folder for each one? I'll try that after I put them back to "Movies" today. kodi.log
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 @@riffy I might have an idea. Give me a few to make you a new build to test. Thanks for helping fix this issue.
riffy 32 Posted November 4, 2015 Posted November 4, 2015 Cool! Just sitting here watching TV & messin with my doggies anyways. :-D
Angelblue05 4132 Posted November 5, 2015 Posted November 5, 2015 (edited) @@riffy Here you go. Don't forget to enable logging in the add-on itself (in your last log, it was set to None. Need it to be set to Info) Thanks! Hopefully this one will fix it. I'm very confident it will, but you never know! Edited November 8, 2015 by Angelblue05 1
riffy 32 Posted November 5, 2015 Posted November 5, 2015 oh yeah I bet cuz I did a reset & said yes to reset the settings too. oooops hehe
Angelblue05 4132 Posted November 5, 2015 Posted November 5, 2015 I'm really hoping I got it right this time... otherwise I just don't know what else we could do. If we don't force update your kodi library, then you won't see changes happen right away. You'd need to back out of menus and re enter to see updates, which is not ideal.
riffy 32 Posted November 5, 2015 Posted November 5, 2015 Looks like you got it! Woke up to it still syncing, haven't had that in weeks now. :-) 2
Angelblue05 4132 Posted November 5, 2015 Posted November 5, 2015 That's great news riffy, really excellent news. The fix will be in the next beta release. Thanks for helping test beta Sent from my iPhone using Tapatalk 1
Angelblue05 4132 Posted November 8, 2015 Posted November 8, 2015 The fix is in the latest beta version 1.1.55. Thanks everyone!
