brindosch 1 Posted October 29, 2015 Posted October 29, 2015 (edited) same problem here. system: kodi 15.2, fresh reset just the emby addon 1.1.53. the log just to be sure kodi.log Edited October 29, 2015 by brindosch
Angelblue05 4132 Posted October 29, 2015 Posted October 29, 2015 @@brindosch You don't have the same issue. Next time don't forget to enable the add-on debug (add-on settings > advanced > log level: Info). Looking into your issue to find an explanation because it's a weird one. Are you using direct paths (add-on settings > sync option > local paths enabled)?
brindosch 1 Posted October 29, 2015 Posted October 29, 2015 (edited) I think i found the bug! Yesterday evening i played around with .strm files in emby. The paths to tv-shows won´t sync. Then i added a movie-dummy.strm and now the sync stops every time at movie 54/251. If i use no local paths, then all is ok, if i use local paths, no paths to .strm files are synced to kodi. I deleted the movie-dummy.strm and all is working fine again I made some screenshots of the odd behaviour of tv shows. Here you see the Meta Manager http://www.directupload.net/file/d/4155/94lybho6_jpg.htm And in Kodi: This is the root of the tv-show overview. This is the only path that is synced to kodi. I have no paths to seasons or episodes. http://www.directupload.net/file/d/4155/xwugd3vs_jpg.htm And here is the "DEBUG" logfile with "A Movie Dummy.strm". The Emby-Server named it "Title: Saneamento Básico, O Filme" it is at the end of log Update 1: Tested the incremental sync server plugin with .strm. The .strm movie is not synced. The same error expetion. Debug log is added. kodi.log kodiIncrementalSync.log Edited October 29, 2015 by brindosch
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 (edited) @@riffy I'm sorry for the wait, needed a break Can you test this custom build? Just install from zip, over the current version and let me know if you still get the issue. If you do, please post your kodi log, I've added additional logging. Thank. Edited November 4, 2015 by Angelblue05
riffy 32 Posted November 3, 2015 Posted November 3, 2015 Ok... see what happens. :-) BTW... I've noticed when I turn on the notifications, it's been locking up a lot when it does the compress database. Like for a few seconds at a time the windows 10 busy circle pops up each time.
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 (edited) Yes, that's what I'm trying to correct. We force update kodi library when we update your database with new emby info (playstate, additions, etc), so you can see the change instantly. For some reason, you have an update once every 4 seconds, rather than a batch of updates at once. So if we force update your Kodi library, there's a good chance it will run at the same time as the new update we receive 4 seconds later. Edited November 3, 2015 by Angelblue05
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 @brindosch The bug you've uncovered is fixed for the next beta release. The fix is currently in github. Thanks for reporting.
riffy 32 Posted November 3, 2015 Posted November 3, 2015 hehe k Prolly won't mess with it tonight (tired) but I'll play with it tomorrow. It's installed tho. 1
brindosch 1 Posted November 3, 2015 Posted November 3, 2015 (edited) Hello again, thank you for the fix, tested with 1.1.54 Sync don´t stop now on a .strm file. Sadly, the path is still not synced. It gathers the path (saw it in the log) but still not in the DB. odd bug. Debug-log added. Search for .strm kodi.log Edited November 3, 2015 by brindosch 1
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 (edited) Ah, strm file are not currently supported for direct paths, only plugin paths at the moment. (because we need the path to the strm, not what's inside the strm file) It will be supported eventually. Edited November 3, 2015 by Angelblue05
brindosch 1 Posted November 3, 2015 Posted November 3, 2015 (edited) I saw it inside the database of kodi (with SQLite Spy), it syncs only "plugin://plugin.video.XXXXX/" as path and not the path to the file itself - like emby. Would be great - if - this could be done easily. Strange that it can´t just extract the path of the emby db. Thanks for response. Edited November 3, 2015 by brindosch
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 Made a trello card for it: https://trello.com/c/NXokhHhh/177-support-strm-for-direct-paths You can track progress if you'd like.
brindosch 1 Posted November 3, 2015 Posted November 3, 2015 (edited) Thank you for the trello card! I made a screenshot of the actual behaviour, maybe that would help if you have some time in future. Don´t hesitate if you need someone for testing or further information I really respect your hard work on this plugin in your free-time. https://picload.org/image/plawdda/strmdatabase.jpg Edited November 3, 2015 by brindosch
riffy 32 Posted November 3, 2015 Posted November 3, 2015 Nope... woke up & saw it had stopped syncing during the night still. Ran manual sync & exited. :-( btw... manual sync runs multiple times now instead of just once. It also added my music to kodi & I had that set not too, to speed up the manual sync. Music gets stuck at 99% on both albums & songs for like 2-3 mins each time other wise. Making the time like almost 10 mins just to sync with the multiple runs & music hangs. It took over 25 mins to run a manual sync this time tho. Some of that time might have been it adding the music that wasn't in the library before. Like I said had it set to not add it. Still crazy amount of time tho to sync. Still froze for 3-4 seconds in the end too. kodi.zip
xnappo 1611 Posted November 3, 2015 Posted November 3, 2015 @@riffy - did you see it do something weird like bounce between collections over and over again while it was syncing? I saw that myself last night but lost the log unfortunately.
Angelblue05 4132 Posted November 3, 2015 Posted November 3, 2015 (edited) Nope... woke up & saw it had stopped syncing during the night still. Ran manual sync & exited. :-( btw... manual sync runs multiple times now instead of just once. It also added my music to kodi & I had that set not too, to speed up the manual sync. Music gets stuck at 99% on both albums & songs for like 2-3 mins each time other wise. Making the time like almost 10 mins just to sync with the multiple runs & music hangs. It took over 25 mins to run a manual sync this time tho. Some of that time might have been it adding the music that wasn't in the library before. Like I said had it set to not add it. Still crazy amount of time tho to sync. Still froze for 3-4 seconds in the end too. Thanks, will keep looking into a solution. At least with the additional logging, it helps me find the source of the problem. @@xnappo you also have this issue? It's the update video library, I will try to completely remove it to confirm. Edited November 3, 2015 by Angelblue05
riffy 32 Posted November 3, 2015 Posted November 3, 2015 @@riffy - did you see it do something weird like bounce between collections over and over again while it was syncing? I saw that myself last night but lost the log unfortunately. Yup... does it every time now.
xnappo 1611 Posted November 4, 2015 Posted November 4, 2015 Yeah, I have seen it twice but can't recreate it. The machine I see it on is on stable though - is this just a random problem that has been there for a while?
riffy 32 Posted November 4, 2015 Posted November 4, 2015 (edited) It's new as of a week or less ago. It happens every single time I do a manual sync. edit: the bouncing around during a sync that is. :-) Edited November 4, 2015 by riffy
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 (edited) Yeah, I have seen it twice but can't recreate it. The machine I see it on is on stable though - is this just a random problem that has been there for a while? Yeah, I mean, the force update library for Kodi has been there for a while. I've only seen it happen under extreme situation when I was getting all the person update before I disable the automatic task. When the trakt import playstate task was running I mean. @@riffy There is something weird with your server. As I said before, you receive a new update every 4 seconds, one item at a time? It's not normal. It's causing this "extreme" situation on the update process and it making your kodi library update every 4 seconds (everytime you receive a message) It's your playstate being constantly updated. Do you have something set up, like trakt import task or? You have similar messages once, every 4 seconds, with different ids (some repeat). I'm still working on making the process more resilient. But something is not right on your side either. 02:25:56 T:8264 NOTICE: EMBY WebSocketThread -> Message: {"MessageType":"UserDataChanged","Data":{"UserId":"fcbdddb4c1894b17b4760310ba2e6e3d","UserDataList":[{"PlaybackPositionTicks":0,"PlayCount":0,"IsFavorite":false,"Played":false,"ItemId":"8272f3e017cfcc684b2ac1e5616077e2"},{"PlayedPercentage":22.65625,"UnplayedItemCount":297,"PlaybackPositionTicks":0,"PlayCount":0,"IsFavorite":false,"Played":false,"Key":"2e257401-5bb8-8a22-a039-32d6194cfa03","ItemId":"2e2574015bb88a22a03932d6194cfa03"}]}} 02:25:56 T:8264 NOTICE: EMBY WebSocketThread -> Message: Doing UserDataChanged: UserDataList: [{u'ItemId': u'8272f3e017cfcc684b2ac1e5616077e2', u'PlayCount': 0, u'PlaybackPositionTicks': 0, u'IsFavorite': False, u'Played': False}, {u'ItemId': u'2e2574015bb88a22a03932d6194cfa03', u'IsFavorite': False, u'Played': False, u'PlayedPercentage': 22.65625, u'UnplayedItemCount': 297, u'PlaybackPositionTicks': 0, u'Key': u'2e257401-5bb8-8a22-a039-32d6194cfa03', u'PlayCount': 0}] 02:25:56 T:8264 NOTICE: EMBY LibrarySync -> Doing LibraryChanged : Processing User Data Changed : [{u'ItemId': u'8272f3e017cfcc684b2ac1e5616077e2', u'PlayCount': 0, u'PlaybackPositionTicks': 0, u'IsFavorite': False, u'Played': False}, {u'ItemId': u'2e2574015bb88a22a03932d6194cfa03', u'IsFavorite': False, u'Played': False, u'PlayedPercentage': 22.65625, u'UnplayedItemCount': 297, u'PlaybackPositionTicks': 0, u'Key': u'2e257401-5bb8-8a22-a039-32d6194cfa03', u'PlayCount': 0}] 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Processing items: [{u'ItemId': u'8272f3e017cfcc684b2ac1e5616077e2', u'PlayCount': 0, u'PlaybackPositionTicks': 0, u'IsFavorite': False, u'Played': False}, {u'ItemId': u'2e2574015bb88a22a03932d6194cfa03', u'IsFavorite': False, u'Played': False, u'PlayedPercentage': 22.65625, u'UnplayedItemCount': 297, u'PlaybackPositionTicks': 0, u'Key': u'2e257401-5bb8-8a22-a039-32d6194cfa03', u'PlayCount': 0}] 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Item 2e2574015bb88a22a03932d6194cfa03 is not found in Kodi database. 02:25:56 T:22640 NOTICE: EMBY WriteKodiVideoDB -> Found embyId: 8272f3e017cfcc684b2ac1e5616077e2 in database - kodiId: 1333 fileId: 1333 type: movie 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Commit successful. 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Updating video library. 02:25:56 T:19920 NOTICE: VideoInfoScanner: Starting scan .. 02:25:56 T:19920 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Sync Database, Incremental Sync Using Client Time -5 min: 2015-11-03T08:20:56Z 02:25:56 T:22640 NOTICE: EMBY LibrarySync -> Sync Database, Incremental Sync Setting Last Run Time Saved: 2015-11-03T08:20:56Z Edited November 4, 2015 by Angelblue05
riffy 32 Posted November 4, 2015 Posted November 4, 2015 I have the trakt plugin on the server, but it's scheduled to only run at startup. This is a new install of kodi & I wiped the database of emby just last week, er... 2-3 weeks ago. So everything should be fresh on both server & kodi. *shrug*
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 (edited) Ok, so what's causing your server to send all those messages. There must be a reason. @ @@xnappo can you take a look at the log found here: http://emby.media/community/index.php?/topic/26206-emby-for-kodi-stops-syncing/?p=263745 It's odd that you get two messages for one item. One for the playstate and another for the item itself was modified (anything from artwork to metadata). Do you use nfos? Edited November 4, 2015 by Angelblue05
riffy 32 Posted November 4, 2015 Posted November 4, 2015 Yeah I think... the settings under metadata is set to use em. I don't know where else there'd be a setting for nfos.
Angelblue05 4132 Posted November 4, 2015 Posted November 4, 2015 (edited) @@riffy Can you try this build: I tried adjusting some values to see if it's any better. As usual, if it still happens, post a new log. Thanks Edited November 5, 2015 by Angelblue05
riffy 32 Posted November 4, 2015 Posted November 4, 2015 Installed... see what happens. Anything I can do to speed it up or just wait & see?
