Emby for Kodi stops syncing
I have several Pi 2's and after a while the stop recieving updates until they are restarted. Looking at the log files I am seeing an error about the database being locked at the time it stops syncing.
Normally I use Kodi 16 but I went ahead and downgraded my openelec to see if I got the error on Kodi 15 which I still do.
Kodi 15 log file
Kodi (15.1 Git:f4dda26)
https://www.dropbox.com/s/2ittyoj1g4tu5gq/kodi2.log?dl=0
OpenELEC (official) - Version: 5.95.5 6.0, kernel: Linux ARM 32-bit version 4.1.6
Kodi 16 log file
Kodi (16.0-ALPHA4 Git:4173817)
OpenELEC (Milhouse) - Version: devel-20151006001946-#1005z-gdc340f5 [build #1005z] 6.0, kernel: Linux ARM 32-bit version 4.1.8
https://www.dropbox.com/s/byv7cei6wu4b6ss/kodi1.log?dl=0
23:52:45 36411.976562 T:1846514752  NOTICE: EMBY WebSocketThread -> logMsg : sendProgressUpdate
23:52:45 36411.984375 T:1846514752  NOTICE: EMBY WebSocketThread -> logMsg : Message data: {"Data": "{\"ItemId\": \"fcd913c78c0d9e44871afb9dc10b1941\", \"QueueableMediaTypes\": \"Video\", \"SubtitleStreamIndex\": \"\", \"MediaSourceId\": \"fcd913c78c0d9e44871afb9dc10b1941\", \"IsMuted\": false, \"PositionTicks\": 77410001, \"IsPaused\": false, \"CanSeek\": true, \"VolumeLevel\": 94, \"PlayMethod\": \"DirectPlay\", \"AudioStreamIndex\": 1}", "MessageType": "ReportPlaybackProgress"}
23:52:47 36414.335938 T:1658758208   ERROR: Exception in thread Thread-110:
                                            Traceback (most recent call last):
                                              File "/home/stephan/projects/openelec-6.0/build.OpenELEC-RPi2.arm-5.95.5/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 1110, in run
                                                self.setUserdata(listItems)
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 932, in setUserdata
                                                cursorvideo.execute("SELECT media_type FROM emby WHERE emby_id = ?", (itemId,))
                                            OperationalError: database is locked
23:52:50 36416.988281 T:1846514752  NOTICE: EMBY Player -> logMsg : reportPlayback Called
Edited by agentxan
MSattler
Kodi 15 log file
Kodi 16 log file
It may help to know what Kodi AddOn's you are running.  In case one of these is locking the db.
The addons that I have installed are
Backup
Emby 1.1.44
Keymap Editor
Openelec Configuration
Openelec Dev Update
Common Plugin Cache
Openelec Rpi Config
Skin Widgets
Universal - An Addons Toolkit
Amber Skin
TwitchTV
Youtube
Here is a Kodi debug log that list every plugin.
http://xbmclogs.com/psp3ddhdt
Edited by agentxan
Angelblue05
Can you try disabling universal - an addons toolkit and let me know if you still get an error?
Edit: it might be something else... I'm still looking at your logs. Will let you know if I find anything.
Sent from my iPhone using Tapatalk
Edited by Angelblue05
Angelblue05
Ok thanks, still looking into it.
MSattler
I think I see this occasionally as well.  Tonight I saw it on the tv show side.
Angelblue05
I will need to make a version with additional logging. I'm putting it together as we speak. There's one area I suspect might be causing this issue, but I'll need more information because I do not have this issue with 1.1.44.
Angelblue05
@@agentxan
Please install this custom version. It won't fix the issue because I need more information at this point. Set the add-on debug to Info, no need to be set to debug pass this point. Please post your Kodi log when the error happens (database is locked). Thank you.
I downloaded and installed the test version. Once I see the error I will post back.
  • Like 2
Here is the error and the latest log with the emby version from this thread.
https://www.dropbox.com/s/zi82venrlgczflg/kodi4.log?dl=0
01:29:16 10435.627930 T:1670378560  NOTICE: EMBY LibrarySync -> Incremental sync, processing tvshows.
01:29:16 10435.774414 T:1670378560  NOTICE: EMBY LibrarySync -> Incremental sync, processing episode.
01:29:25 10444.553711 T:1670378560   ERROR: Exception in thread Thread-72:
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 1109, in run
                                                self.IncrementalSync(listItems)
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 722, in IncrementalSync
                                                cursor.execute("SELECT kodi_id FROM emby WHERE media_type='tvshow' AND emby_id=?", (MBitem["SeriesId"],))
01:29:25 10444.650391 T:1462658112  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:28
01:29:25 10445.193359 T:1670378560  NOTICE: Thread BackgroundLoader start, auto delete: false
01:30:00 10479.433594 T:1678767168  NOTICE: Previous line repeats 1 times.
richardap1
Interesting. I am see this too. However a manual resync will work. But it will then stop background syncing.
I was wondering about the status of this error . I have updated to the latest emby for kodi beta 1.1.51 and am still getting the error. This is on three different pi 2's.
EMBY Version: 1.1.51
http://xbmclogs.com/pazbz3dds
13:13:48 1210.108521 T:1652552768  NOTICE: EMBY LibrarySync -> Doing LibraryChanged : Processing Added and Updated : [u'0a600d5659fd4a384480c54e3d88639f', u'4c323c80755d442c8ca615bfcbe54581', u'e97d5a83519f1beb45c46f124ba83196', u'94f3a9b73bc63ed15db168080ae813a1']
13:13:58 1219.950806 T:1644164160   ERROR: Exception in thread Thread-42:
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 1114, in run
                                              File "/storage/.kodi/addons/plugin.video.emby/resources/lib/LibrarySync.py", line 936, in setUserdata
13:13:58 1220.107056 T:1553372224  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:22
Angelblue05
Something is keeping your database open. I'm not sure what, because we only use one connection to the database at a time to avoid this situation. Do you have anything else in your Kodi? Do you have videos imported into Kodi? If you go to videos > files, do you see anything? Let me know...
Right now I have a fresh .kodi directory with just emby for kodi installed. In the videos > files there is nothing listed.
Angelblue05
Ok, well I'm still looking into it. I will let you know if I find anything. Thanks for your patience.
Angelblue05
It seems to be a timing issue. Everytime you got the error, the kodi's videoinfoscanner was running at the exact same time. If it happened to run exactly when we processed something, this would happen:
I'll look into a solution for this, as I'm 100% (ok, 95% :) ) sure that's what causing your issue.
Angelblue05
@@agentxan
Please try this custom build. Trying something out. If the issue still happens, I will take it a step further. Thank!
  • Like 1
I have been using this custom build on all three of my pi 2's for over 24 hours now and have not saw any error. Thank you for the good work.
  • Like 2
Try the custom build up a couple posts.
Angelblue05
The fix is included in the latest beta version 1.1.53.
  • Like 1
Will test it this weekend.  Ya know, has anyone done a video yet from the standpoint of fresh Kodi install, installing the Emby Plugin, and then Arctic Zephyr?
May help more people understand how it all works.
Not the skin, but the first two yes..
  • Like 1
I think I'm having this too. Syncs fine at startup but doesn't ever add new items later. Been doing this for a couple weeks & I did a full database wipe on the server & full reinstall for Kodi yesterday & it's still doing it.
Emby 1.1.53, Server 3.0.5768.6, Kodi 15.2, with Titan 3.4.13
Edit: Added Log. Ran for awhile with it never adding anything new until I did a manual sync & it added 2 items.
kodi.log
Edited by riffy
Angelblue05
Ok, then I guess I'll have to fix this, a step further than what I already put in place. You will need to give me a bit for the fix. I'll let you know once I have something for you to test @@riffy. Thanks
  • Like 1
Guest
