krustyreturns 191 Posted December 11, 2015 Posted December 11, 2015 Will do. I just can't decide how or if I want to do it. I really wanted to keep emby to just using http and not having users setup network share folders. Even if I do it, its not a 100% solution because in the case where the user wants to watch a file that is in the process of being recorded its not clear whether to use an http stream so that emby can detect that the file is still growing, or just let it play the active wtv file. In the first case trick play won't work, in the second case the playback will end early. Do you have a preference? I can't help thinking it would be cleaner to send the media info, but I may not be anticipating all the problems there either. 1
bmoses 9 Posted December 11, 2015 Author Posted December 11, 2015 Will do. I just can't decide how or if I want to do it. I really wanted to keep emby to just using http and not having users setup network share folders. Even if I do it, its not a 100% solution because in the case where the user wants to watch a file that is in the process of being recorded its not clear whether to use an http stream so that emby can detect that the file is still growing, or just let it play the active wtv file. In the first case trick play won't work, in the second case the playback will end early. Do you have a preference? I can't help thinking it would be cleaner to send the media info, but I may not be anticipating all the problems there either. i'm probably a minority here, but we rarely ever watch recorded TV shows while they are still recording, it is always done after the recording has finished. also i don't know if this matters but in my setup WMC records the shows to a d:\recorded TV folder, but then i have a script that runs every hour that moves the WTV files to my server in a shared recorded TV folder. serverwmc sees both folders and everything, other than this issue, works with that setup.
Luke 42287 Posted December 11, 2015 Posted December 11, 2015 Will do. I just can't decide how or if I want to do it. I really wanted to keep emby to just using http and not having users setup network share folders. Even if I do it, its not a 100% solution because in the case where the user wants to watch a file that is in the process of being recorded its not clear whether to use an http stream so that emby can detect that the file is still growing, or just let it play the active wtv file. In the first case trick play won't work, in the second case the playback will end early. Do you have a preference? I can't help thinking it would be cleaner to send the media info, but I may not be anticipating all the problems there either. It's fine, I will add the ability for you to send back the media info if that's what you end up preferring.
krustyreturns 191 Posted December 11, 2015 Posted December 11, 2015 It's fine, I will add the ability for you to send back the media info if that's what you end up preferring. Thanks @@Luke. Let me work the through the ramifications on my side first, and I'll let you know.
btgerold 3 Posted December 12, 2015 Posted December 12, 2015 Will do. I just can't decide how or if I want to do it. I really wanted to keep emby to just using http and not having users setup network share folders. Even if I do it, its not a 100% solution because in the case where the user wants to watch a file that is in the process of being recorded its not clear whether to use an http stream so that emby can detect that the file is still growing, or just let it play the active wtv file. In the first case trick play won't work, in the second case the playback will end early. Do you have a preference? I can't help thinking it would be cleaner to send the media info, but I may not be anticipating all the problems there either. For what its worth, The only things we watch live is sports. Pretty much everything else is after the fact. Same as bmoses I'm more than willing to be a guinea pig.
Solution krustyreturns 191 Posted December 16, 2015 Solution Posted December 16, 2015 @@bmoses and @@btgerold I have a pre-release you can test (1224). You can get it from here: http://bit.ly/swmcBeta-1224 See the settings on the http service tab of serverwmc. It enables you to set http streaming for live tv and file-based playback for recorded tv. 1
btgerold 3 Posted December 16, 2015 Posted December 16, 2015 @@bmoses and @@btgerold I have a pre-release you can test (1224). You can get it from here: http://bit.ly/swmcBeta-1224 See the settings on the http service tab of serverwmc. It enables you to set http streaming for live tv and file-based playback for recorded tv. @@krustyreturns - Installed. Have http for live TV, but not for recorded files. Right now I'm checking just from the web browser interface. Live TV is playing now, ... Pausing is working. Backing the program up works, but when you FF, it doesn't to have any rhyme or reason for where it goes, and you can get stuck significantly behind where live is... I can't rememeber how well it worked before though.... Recorded TV is also playing. FF and rewind having no issues. Resume also seems to be working. Media info also populated after some time.... 1
krustyreturns 191 Posted December 16, 2015 Posted December 16, 2015 Thanks for testing so quick. Live-tv should be just as it was before for http mode. Mainly the change to use the file paths instead of http for recorded tv files, while simultaneously keeping http mode for live-tv. 1
bmoses 9 Posted December 16, 2015 Author Posted December 16, 2015 @@bmoses and @@btgerold I have a pre-release you can test (1224). You can get it from here: http://bit.ly/swmcBeta-1224 See the settings on the http service tab of serverwmc. It enables you to set http streaming for live tv and file-based playback for recorded tv. you are awesome!!!!! i will do some more testing tonight when i'm at home with the nexus player and fire tv stick, but i remoted into my desktop just now and installed the patch and did some tests through the web client player and everything looked good so far!! i will need to apply this fix to my parents setup as well, should i use this beta version or will a "formal" release happen soon? quick question i've been meaning to ask but not related to this issue. in serverwmc on the "recordings" tab there is an option to remove info/commercial files when a recording is deleted. I added in "JPG" as a file extension to that section so that when i delete a recorded show from within emby it would also delete the JPG poster file that emby creates as well, this doesn't appear to be working though as the WTV file gets deleted but the JPG file is left. any thoughts on why that wouldn't be working?
krustyreturns 191 Posted December 16, 2015 Posted December 16, 2015 Thanks. Does emby create the jpg poster in the same directory as the corresponding recorded tv file? With the same name as the wtv file (excluding the extension)?
bmoses 9 Posted December 16, 2015 Author Posted December 16, 2015 Thanks. Does emby create the jpg poster in the same directory as the corresponding recorded tv file? With the same name as the wtv file (excluding the extension)? it does get created in the same folder, and has the same name as the file but adds a -poster to the end of the file name. sometimes there are XML files in the folder with the recorded TV shows and those get deleted OK. so presumably they aren't getting deleted because of the -poster added to the name.
krustyreturns 191 Posted December 16, 2015 Posted December 16, 2015 Yeah, that's why. I didn't write this part of swmc, but I will take a look and see if there is something q&d I can do.
bmoses 9 Posted December 16, 2015 Author Posted December 16, 2015 Yeah, that's why. I didn't write this part of swmc, but I will take a look and see if there is something q&d I can do. awesome, thanks! and i'll let you know how testing goes tonight on the other issue
krustyreturns 191 Posted December 16, 2015 Posted December 16, 2015 Just double checking, the jpg file name is: WtvFileNameWithoutExtension-poster.jpg correct?
bmoses 9 Posted December 16, 2015 Author Posted December 16, 2015 Just double checking, the jpg file name is: WtvFileNameWithoutExtension-poster.jpg correct? yep, here is a copy/paste of one American Pickers_HIST_2015_07_15_19_58_00.wtv American Pickers_HIST_2015_07_15_19_58_00-poster.jpg
krustyreturns 191 Posted December 17, 2015 Posted December 17, 2015 (edited) Got it, thanks. It was an easy change, i will be in the coming release which I hope to do in the next few days. Edited December 17, 2015 by krustyreturns 1
bmoses 9 Posted December 17, 2015 Author Posted December 17, 2015 Got it, thanks. It was an easy change, i will be in the coming release which I hope to do in the next few days. sweet! was just coming here to post that i just got done testing the fix for the other issue on my fire tv stick and nexus player and everything is working perfectly! 1
bmoses 9 Posted April 23, 2016 Author Posted April 23, 2016 sorry to bump an old thread but this issue appears to be back. i'm on serverwmc build 1229 and emby server 3.0.5943.0. when trying to watch a recorded TV on either the web player or android TV on my nexus players i can not resume, FF, or rewind. I tested on emby on my android phone and it works fine there. i also tested emby theater and it works there, but it was also direct streaming on that. when i try to FF the counter resets to 0 and then nothing plays but the counter starts counting up. i will upload the transcode log in a few. @@krustyreturns @@Luke
bmoses 9 Posted April 23, 2016 Author Posted April 23, 2016 attached are 2 transcode logs from an attempt to play a recorded TV show. transcode-f18d190e-c68a-4b07-93f7-022cabe531ce.txt transcode-1707da64-f0cd-48a0-b49e-bd8881d2b62d.txt
Luke 42287 Posted April 23, 2016 Posted April 23, 2016 attached are 2 transcode logs from an attempt to play a recorded TV show. transcode-f18d190e-c68a-4b07-93f7-022cabe531ce.txt transcode-1707da64-f0cd-48a0-b49e-bd8881d2b62d.txt As a test, can you try adding that recording as an emby server library and then play it once the library scan has completed? in other words, just make a test folder and then setup a home video library. Thanks.
bmoses 9 Posted April 23, 2016 Author Posted April 23, 2016 As a test, can you try adding that recording as an emby server library and then play it once the library scan has completed? in other words, just make a test folder and then setup a home video library. Thanks. same behavior, attached the transcode log for that test. transcode-870f3d73-a3f7-4dec-bca7-d51b2e0d1f56.txt transcode-80a17b9e-3d96-439d-bd66-c7923af43c56.txt
Luke 42287 Posted April 23, 2016 Posted April 23, 2016 can you please provide a sample file for testing. thanks.
bmoses 9 Posted April 23, 2016 Author Posted April 23, 2016 can you please provide a sample file for testing. thanks. EBR should still have access to my server, will that work? if not i'll record a short time and post a link to it.
bmoses 9 Posted April 23, 2016 Author Posted April 23, 2016 a downloadable file is best. here you go https://drive.google.com/file/d/0B379XYZRGuIyU0syc3c2MHY2ZVE/view?usp=sharing thanks!
