cdarney3 6 Posted October 4, 2015 Posted October 4, 2015 I'm really about to go nuts here!. I'm just trying to change the location where my recorded TV goes. Currently they're being saved on my local Windows 7 drive (C:\Users\Penny\AppData\Roaming\Emby-Server\data\livetv\recordings) but a really want them to go to a network drive. I've tried in Metadata Manager, added new Media Folders with path substitution. I'm just at a loss. What's the most acceptable way to have a media folder record to a network drive? Should I have a different Media Folder that points to a different recording location? Can I change the location of the recordings for the default "Recorded TV" media folder? I still have Windows Media Center installed becuase I need to make sureEmby works properly before losing my wife's recordings. Could WMC be causing a problem? I'm using: Windows 7 HD HomeRun Connect
Solution mellomade 141 Posted October 4, 2015 Solution Posted October 4, 2015 You can set your recording path from the Dashboard by going to Live TV - Settings and entering a UNC path to your networked drive. WMC or its settings have no effect on EmbyTV. I use WMC to record simulataneously with EmbyTV (for testing purposes) and they both work great together. 1
cdarney3 6 Posted October 4, 2015 Author Posted October 4, 2015 (edited) Thank you very much for this! I was able to record to where I wanted. I don't know how I was missing that configuration settings. I was all over that area and don't remember seeig it. Now, once I get the app configured...AGAIN...maybe I'll be able to watch the recorded shows! ...Chuck Edited October 4, 2015 by cdarney3
