fodbrothers 1 Posted October 2, 2015 Posted October 2, 2015 so I have changed all the permissions correctly. but when I scan it stops at 33.2% which I am very sure it is due to the images that emby create have the wrong permission meaning when it goes to access the file aftwr creating it. it simply cannot thanks to msatter for getting me so far but we have one more and hopefully last error
Luke 42239 Posted October 2, 2015 Posted October 2, 2015 well need to prove it first. please see http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ to supply more info. thanks.
fodbrothers 1 Posted October 2, 2015 Author Posted October 2, 2015 sorry luke so the logs are attached I have checked to see if the file is there in the temp folder which it is (it may not add up to both the reports as I have tried deleting the files in the temp folder to fix the issue) but it is there and as you can see even the logs are created with the wrong permissions any help would be great It may not be the permissions as an issue but it is a guess New Bitmap Image (2).bmp New Bitmap Image.bmp server-63579332824.txt server-63579415833.txt
Luke 42239 Posted October 3, 2015 Posted October 3, 2015 we're just using basic operating system methods to read and write files. the files are marked read/write, how are they wrong?
fodbrothers 1 Posted October 4, 2015 Author Posted October 4, 2015 I am not saying they are it was a guess. as u can see there is a issue somewhere and I was just trying to help as i thought it was that. :-)
Luke 42239 Posted October 4, 2015 Posted October 4, 2015 well right now we're going about this wrong because you've told us what you think the problem is and we're basically debugging off that, when we should instead go back to whatever your original problem is and see post #2.
fodbrothers 1 Posted October 5, 2015 Author Posted October 5, 2015 I am only put what myself and msattler thought what it was sorry. and which post r u reffering to . and I have added the logs above so I am guessing you should know what the problem is by that. ( I am not the best person at reading them myself)
Luke 42239 Posted October 5, 2015 Posted October 5, 2015 please enable debug logging under advanced, restart the server, run a library scan, give it several minutes, then post that log. thanks.
fodbrothers 1 Posted October 6, 2015 Author Posted October 6, 2015 ok so I have done that and it is attached, really hope u can help server-63579755174.txt
MSattler 390 Posted October 8, 2015 Posted October 8, 2015 Luke are you able to help ? You only posted part of the server log. Copy and paste the entire server log into pastebin.org and then update the ticket with the link. The portion you posted does still show an issue reading one of the files, but there could be other clues in the full log.
fodbrothers 1 Posted October 8, 2015 Author Posted October 8, 2015 that was the only log in the folder created by the server. it was unedited so i dont know what to do. I will try again and see what comes out
fodbrothers 1 Posted October 8, 2015 Author Posted October 8, 2015 hope this will help you to help me server-63579755174.txt server-63579851653.txt server-63579921833.txt
fodbrothers 1 Posted October 10, 2015 Author Posted October 10, 2015 deleting emby now shame it didnt work for me maybe one day I will come back, when things are fixed
