denethor 90 Posted October 1, 2015 Posted October 1, 2015 To take advantage the new fix I tried reset my DB and sync. But I got below error on Jarvis (16.0-ALPHA3 Git:20150909-c1c54b4) Emby version is 3.0.5724.6 22:07:50 T:3832 NOTICE: -->Python Interpreter Initialized<-- 22:07:50 T:3832 NOTICE: plugin.video.emby started 22:07:50 T:3832 NOTICE: Parameter string: ?mode=manualsync 22:07:50 T:3832 NOTICE: EMBY WriteKodiVideoDB -> Movie Id: d456eb624f7a3b16d158459338ff941c not found. 22:07:50 T:3832 NOTICE: EMBY WriteKodiVideoDB -> ADD movie to Kodi Library, Id: d456eb624f7a3b16d158459338ff941c - Title: Winged Migration 22:07:50 T:3832 NOTICE: Sync DB -> syncDatabase Exiting 22:07:50 T:3832 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'sqlite3.OperationalError'> Error Contents: no such table: path Traceback (most recent call last): File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 125, in <module> Main() File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py", line 66, in __init__ LibrarySync().FullLibrarySync(True) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 147, in FullLibrarySync self.MoviesFullSync(connection,cursor,pDialog) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\LibrarySync.py", line 274, in MoviesFullSync WriteKodiVideoDB().addOrUpdateMovieToKodiLibrary(item["Id"],connection, cursor, title) File "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\WriteKodiVideoDB.py", line 189, in addOrUpdateMovieToKodiLibrary cursor.execute("SELECT idPath as pathid FROM path WHERE strPath = ?", (path,)) OperationalError: no such table: path -->End of Python script error report<-- 22:07:50 T:3832 WARNING: CPythonInvoker(39, C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py): the python script "C:\Users\username\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class XBMCAddon::xbmcgui::Window,class XBMCAddon::xbmcaddon::Addon 22:07:50 T:4180 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.emby/?mode=manualsync 22:07:50 T:4180 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.emby/?mode=manualsync) failed 22:07:50 T:8704 NOTICE: Thread LanguageInvoker start, auto delete: false 22:07:50 T:8704 NOTICE: -->Python Interpreter Initialized<--
im85288 1493 Posted October 1, 2015 Posted October 1, 2015 Jarvis is not supported, however it's working fine on my version. What version of the video database do you have locally?
denethor 90 Posted October 1, 2015 Author Posted October 1, 2015 Jarvis is not supported, however it's working fine on my version. What version of the video database do you have locally? 22:11:14 T:11712 NOTICE: Running database version MyVideos96
Solution im85288 1493 Posted October 1, 2015 Solution Posted October 1, 2015 There's your problem, for anyone else using Jarvis make sure to use the latest nightly versions before posting here. The version it requires is now 97. 2
denethor 90 Posted October 1, 2015 Author Posted October 1, 2015 There's your problem, for anyone else using Jarvis make sure to use the latest nightly versions before posting here. The version it requires is now 97. Solved! Thanks. 2
MSattler 390 Posted October 2, 2015 Posted October 2, 2015 (edited) There's your problem, for anyone else using Jarvis make sure to use the latest nightly versions before posting here. The version it requires is now 97. Where are the nightlies? Edited October 2, 2015 by MSattler
im85288 1493 Posted October 2, 2015 Posted October 2, 2015 Jarvis nightly versions http://kodi.tv/download/ 1
MSattler 390 Posted October 2, 2015 Posted October 2, 2015 Jarvis nightly versions http://kodi.tv/download/ I thought you meant EmbySync not Kodi, my bad =)
crystalgipsy 4 Posted October 10, 2015 Posted October 10, 2015 Just got a Shield TV and wanted to test the auto framerate switching, But I cant get the addon to sync my library at all to the latest nightly of Jarvis it just falls over. Looking in the profile directory I see two video db one is 97 the other is 99. Is this likely to be the issue?
crystalgipsy 4 Posted October 10, 2015 Posted October 10, 2015 Spoke too soon for some reason my tv show are not accessible. They are not showing up on the home shelf and when going in to TV Shows I can see the shows but no files show up. Most odd not had this before. Any ideas. Movies seem to work ok.
Angelblue05 4132 Posted October 10, 2015 Posted October 10, 2015 (edited) Make sure your episodes have define season numbers in the webclient metadata manager. Otherwise it will skip adding your episodes during the initial sync in Kodi. Sent from my iPhone using Tapatalk Edited October 10, 2015 by Angelblue05
inesergio 11 Posted October 11, 2015 Posted October 11, 2015 Make sure your episodes have define season numbers in the webclient metadata manager. Otherwise it will skip adding your episodes during the initial sync in Kodi. Sent from my iPhone using Tapatalk Having the same problem. Updated Util.py to use v99 of myvideos.db and theres no episodes inside the séries. Maybe a change in v99? Enviado do meu Q10 através de Tapatalk
Angelblue05 4132 Posted October 11, 2015 Posted October 11, 2015 Do you have season define for the episode, in the metadata manager? Sent from my iPhone using Tapatalk
xnappo 1611 Posted October 11, 2015 Posted October 11, 2015 (edited) Yes, there is a change in 99 that breaks the DB. Remember - we do not support anything officially until RC. @@Angelblue05 - I think it is this Kodi commit: https://github.com/xbmc/xbmc/commit/974668e0a2bf79d2ab4660590088baf67bf2be78 Column for path is moved by one slot.. Edited October 11, 2015 by xnappo 1
inesergio 11 Posted October 11, 2015 Posted October 11, 2015 Yes, there is a change in 99 that breaks the DB. Remember - we do not support anything officially until RC. @@Angelblue05 - I think it is this Kodi commit: https://github.com/xbmc/xbmc/commit/974668e0a2bf79d2ab4660590088baf67bf2be78 Column for path is moved by one slot.. If it's an easy fix can you add the fix to git? If not I will wait or can you tell me where to look in code for a fix? Thank you. Enviado do meu Q10 através de Tapatalk
xnappo 1611 Posted October 11, 2015 Posted October 11, 2015 (edited) It is not an easy fix. If you want to try your hand at it, feel free - look at how the order of the table changed in the Git link I sent. Otherwise, just rollback a bit to an earlier nightly. We don't want to chase it every day, so we are going to wait to see if the change sticks. Edited October 11, 2015 by xnappo
inesergio 11 Posted October 11, 2015 Posted October 11, 2015 It is not an easy fix. If you want to try your hand at it, feel free - look at how the order of the table changed in the Git link I sent. Otherwise, just rollback a bit to an earlier nightly. We don't want to chase it every day, so we are going to wait to see if the change sticks. I complety understand but had to ask. I downgraded and everything works. Thank You Enviado do meu Q10 através de Tapatalk
xnappo 1611 Posted October 11, 2015 Posted October 11, 2015 Did you downgrade just Kodi or also the addon? I am seeing something weird where it is trying to do something like add trailers to TV..
inesergio 11 Posted October 11, 2015 Posted October 11, 2015 (edited) Did you downgrade just Kodi or also the addon? I am seeing something weird where it is trying to do something like add trailers to TV.. Just kodi. The addon I changed back db version to 97. I also deleted Myvideos99.db bu that should make no difference. Let me check if I spot something weird. Edit: all fine on my end. Maybe advancedsettings is corrupt? I think there's excludes in there. Enviado do meu Q10 através de Tapatalk Edited October 11, 2015 by inesergio 1
xnappo 1611 Posted October 11, 2015 Posted October 11, 2015 Thanks - don't worry about it - my dev machine is all borked - just wanted to make sure it wasn't something with the addon as well as the new db structure. xnappo
im85288 1493 Posted October 11, 2015 Posted October 11, 2015 By the way the sync issue is now fixed in 1.1.47
inesergio 11 Posted October 12, 2015 Posted October 12, 2015 By the way the sync issue is now fixed in 1.1.47Thank you Enviado do meu Q10 através de Tapatalk
denethor 90 Posted October 13, 2015 Author Posted October 13, 2015 (edited) There's your problem, for anyone else using Jarvis make sure to use the latest nightly versions before posting here. The version it requires is now 97. Now I have MyVideos99.db in my user data folder with alpha3 and addon started to fail again EDIT: Latest Nightly solved once again Edited October 13, 2015 by denethor 1
