MSattler 390 Posted September 30, 2015 Posted September 30, 2015 Am receiving the following error when trying to transcode one of my movies via the web: Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height Server Version: Version 3.0.5724.6 Here is the log: http://pastebin.com/3krP2BEu MediaInfo: http://pastebin.com/Eyzd3jiK Is it because it is DTS-MA? I swear I have other files with DTS-MA that work without issue. Thanks!
Luke 42186 Posted September 30, 2015 Posted September 30, 2015 try refreshing the content in the web intrerface. looks like the server doesn't have the audio track info for whatever reason. that could be from the same issue that today's server release is intended to fix. unrelated, but since you're on firefox, pretty soon that method of encoding will no longer be used since firefox is finally moving out of the stone age. you can play with firefox 42 beta, see here: http://emby.media/community/index.php?/topic/25956-firefox-42-testing/
MSattler 390 Posted September 30, 2015 Author Posted September 30, 2015 try refreshing the content in the web intrerface. looks like the server doesn't have the audio track info for whatever reason. that could be from the same issue that today's server release is intended to fix. unrelated, but since you're on firefox, pretty soon that method of encoding will no longer be used since firefox is finally moving out of the stone age. you can play with firefox 42 beta, see here: http://emby.media/community/index.php?/topic/25956-firefox-42-testing/ Yup, that did it! My bad, I have Firefox dedicated at work to use a proxy over a ssh tunnel back to my house. Otherwise would have tested Chrome. Thanks!
trusselo 225 Posted February 12, 2016 Posted February 12, 2016 (edited) Im having this issue with chrome trying to sync to my android tablet....fails weather I try the sync from the tablet or computer...rebooted both... C:\Users\Tristyn\AppData\Roaming\Emby-Server\ffmpeg\20151111\ffmpeg.exe -fflags +genpts -i file:"\\Philco\d\tv\The X-Files\Season 3\The X-Files.S03E02.Paper Clip (3).mkv" -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 28 -maxrate 1372000 -bufsize 2744000 -vsync vfr -profile:v high -level 41 -map_metadata -1 -threads 4 -codec:a:0 libmp3lame -ac 6 -ab 128000 -af "aresample=48000:async=1" -y "C:\Users\Tristyn\AppData\Roaming\Emby-Server\sync\ab5d551a63544148ae66715dd9b3b0f8\b94dc132916c41f8a768b10203c02618\b43fcc67f54b4cf2bd3907ed5e872c20.mp4"[/size][/font][/color][/background] ffmpeg version N-76598-g2905c51 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 5.2.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-libvo-aacenc --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 5.100 / 55. 5.100 libavcodec 57. 15.100 / 57. 15.100 libavformat 57. 14.100 / 57. 14.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 15.100 / 6. 15.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:\\Philco\d\tv\The X-Files\Season 3\The X-Files.S03E02.Paper Clip (3).mkv': Metadata: encoder : libebml v1.3.1 + libmatroska v1.4.2 creation_time : 2015-08-16 06:06:14 Duration: 00:45:31.18, start: 0.000000, bitrate: 5613 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default) Metadata: BPS : 5163057 BPS-eng : 5163057 DURATION : 00:45:31.020000000 DURATION-eng : 00:45:31.020000000 NUMBER_OF_FRAMES: 65479 NUMBER_OF_FRAMES-eng: 65479 NUMBER_OF_BYTES : 1762551761 NUMBER_OF_BYTES-eng: 1762551761 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-08-16 06:06:14 _STATISTICS_WRITING_DATE_UTC-eng: 2015-08-16 06:06:14 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) Metadata: BPS : 384000 BPS-eng : 384000 DURATION : 00:45:31.040000000 DURATION-eng : 00:45:31.040000000 NUMBER_OF_FRAMES: 85345 NUMBER_OF_FRAMES-eng: 85345 NUMBER_OF_BYTES : 131089920 NUMBER_OF_BYTES-eng: 131089920 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-08-16 06:06:14 _STATISTICS_WRITING_DATE_UTC-eng: 2015-08-16 06:06:14 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: aac (HE-AAC), 48000 Hz, stereo, fltp Metadata: BPS : 63999 BPS-eng : 63999 DURATION : 00:45:31.179000000 DURATION-eng : 00:45:31.179000000 NUMBER_OF_FRAMES: 64012 NUMBER_OF_FRAMES-eng: 64012 NUMBER_OF_BYTES : 21849430 NUMBER_OF_BYTES-eng: 21849430 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-08-16 06:06:14 _STATISTICS_WRITING_DATE_UTC-eng: 2015-08-16 06:06:14 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(eng): Subtitle: subrip Metadata: title : WEB-DL BPS : 65 BPS-eng : 65 DURATION : 00:45:24.014000000 DURATION-eng : 00:45:24.014000000 NUMBER_OF_FRAMES: 726 NUMBER_OF_FRAMES-eng: 726 NUMBER_OF_BYTES : 22280 NUMBER_OF_BYTES-eng: 22280 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-08-16 06:06:14 _STATISTICS_WRITING_DATE_UTC-eng: 2015-08-16 06:06:14 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4(eng): Subtitle: subrip Metadata: title : WEB-DL SDH BPS : 67 BPS-eng : 67 DURATION : 00:45:24.014000000 DURATION-eng : 00:45:24.014000000 NUMBER_OF_FRAMES: 764 NUMBER_OF_FRAMES-eng: 764 NUMBER_OF_BYTES : 23073 NUMBER_OF_BYTES-eng: 23073 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-08-16 06:06:14 _STATISTICS_WRITING_DATE_UTC-eng: 2015-08-16 06:06:14 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [libx264 @ 0000009c8cc62740] using SAR=1/1 [libx264 @ 0000009c8cc62740] using cpu capabilities: MMX2 SSE2Fast LZCNT [libx264 @ 0000009c8cc62740] profile High, level 4.1 [libx264 @ 0000009c8cc62740] 264 - core 148 r2601 a0cd7d3 - H.264/MPEG-4 AVC codec - Copyleft 2003-2015 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=28.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=1372 vbv_bufsize=2744 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00 [libmp3lame @ 0000009c8c1c00a0] Specified channel layout '5.1' is not supported Output #0, mp4, to 'C:\Users\Tristyn\AppData\Roaming\Emby-Server\sync\ab5d551a63544148ae66715dd9b3b0f8\b94dc132916c41f8a768b10203c02618\b43fcc67f54b4cf2bd3907ed5e872c20.mp4': Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, max. 1372 kb/s, 23.98 fps, 23.98 tbn, 23.98 tbc (default) Metadata: encoder : Lavc57.15.100 libx264 Stream #0:1: Audio: mp3, 0 channels, 128 kb/s (default) Metadata: encoder : Lavc57.15.100 libmp3lame Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> mp3 (libmp3lame)) Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height I successfully synced 2 episodes of the same show with the same source encoding before the fails started happening. now EVERYTHING attempted fails. Edited February 12, 2016 by trusselo
Luke 42186 Posted February 12, 2016 Posted February 12, 2016 thanks, this has been resolved for the next release.
trusselo 225 Posted February 12, 2016 Posted February 12, 2016 (edited) crap.... I'm on a 5 hour bus trip tomorrow.... any known workaround? way to install older working version ect? Edited February 12, 2016 by trusselo
