DLNA blast alive messages not working
Hi,
I have been trying to make DLNA work from Emby with my Onkyo AV receiver, to no avail.
I have created a profile for it, set the blast alive messages from various during durations from 2s to 30s, even deactivating them, deactivated Windows firewall and it does not work.
When I say it does not work, it means that the receiver does not see Emby DLNA server.
Emby server runs on a French Windows 10 and I have 3 Emby Theater clients that work perfectly.
For the sake of testing, I have tested Emby server on an English (US) Windows 10 and the receiver can see this Emby DLNA server right away (even with Windows firewall up).
I have checked that the regional settings and number format are the same on both Windows 10's.
Here is what I see in the logs repeating every X s depending on the configuration of blast alive messages:
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: upnp:rootdevice. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5::upnp:rootdevice. .
	*** Error Report ***
	Version: 3.0.5724.5
	Command line: C:\Users\N54L\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe
	Operating system: Microsoft Windows NT 6.2.9200.0
	Processor count: 2
	64-Bit OS: True
	64-Bit Process: False
	Program data path: C:\Users\N54L\AppData\Roaming\Emby-Server
	Application Path: C:\Users\N54L\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe
	L’adresse demandée n’est pas valide dans son contexte
	System.Net.Sockets.SocketException
	   à System.Net.Sockets.Socket.EndSend(IAsyncResult asyncResult)
	   à MediaBrowser.Dlna.Ssdp.Datagram.<>c__DisplayClass2.<Send>b__0(IAsyncResult result)
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: urn:schemas-upnp-org:device:MediaServer:1. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5::urn:schemas-upnp-org:device:MediaServer:1. .
	Version: 3.0.5724.5
	Processor count: 2
	64-Bit OS: True
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: urn:schemas-upnp-org:service:ContentDirectory:1. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5::urn:schemas-upnp-org:service:ContentDirectory:1. .
	Version: 3.0.5724.5
	Processor count: 2
	64-Bit OS: True
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: urn:schemas-upnp-org:service:ConnectionManager:1. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5::urn:schemas-upnp-org:service:ConnectionManager:1. .
	Version: 3.0.5724.5
	Processor count: 2
	64-Bit OS: True
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1. .
	Version: 3.0.5724.5
	Processor count: 2
	64-Bit OS: True
2015-09-26 16:30:14.6136 Error - SsdpHandler: Error sending Datagram to 127.0.0.1:1900 from 192.168.2.2:0: HTTP/1.1 200 OK. CACHE-CONTROL: max-age = 600. DATE: Sat, 26 Sep 2015 16:30:14 GMT. EXT: . LOCATION: http://192.168.2.2:8096/dlna/dd3808bc7523eca1cafd3f722a8a8fb5/description.xml. SERVER: WIN32/6.2 UPnP/1.0 DLNADOC/1.5 Emby/3.0.5724.5. ST: uuid:dd3808bc7523eca1cafd3f722a8a8fb5. USN: uuid:dd3808bc7523eca1cafd3f722a8a8fb5. .
	Version: 3.0.5724.5
	Processor count: 2
	64-Bit OS: True
I don't know if these messages are the cause of the server not being seen by the Onkyo receiver (Windows network explorer sees Emby just fine).
Any help would be appreciated :)
Thanks!
