badaas 139 Posted September 25, 2015 Posted September 25, 2015 Hi guys,any help? [you really need a server log plugin to pull required logs from server] So refreshed/advance refresh/scan library equals complete mess! Episodes no s/e, or s1 e0. Episodes scraped then listed missing underneath? Also on suggestions some have s/e some dont. Only thing i can think of I went back to beta from latest dev as that was crashing constantly!
badaas 139 Posted September 25, 2015 Author Posted September 25, 2015 ok so gone back to dev no change have just rm'd all *.nfos and now rescanning... zzzzzzzz
badaas 139 Posted September 25, 2015 Author Posted September 25, 2015 So another 2 hours wasted deleting server and all traces, re-install stable and rescan. Back to normal [for now].
Solution Luke 42185 Posted September 25, 2015 Solution Posted September 25, 2015 there are db changes in the dev build so once you switch to that you shouldn't go back. so that explains that. 1
badaas 139 Posted September 25, 2015 Author Posted September 25, 2015 Ok, fair enough. Are there notes on dev build? My bad as per!
