CalypsoCowboy 4 Posted September 25, 2015 Posted September 25, 2015 I have a Nexus Player, when I select Live TV, I'm presented with a logo list of channels from my NextPVR setup. I can select a channel and then go into I'm guessing the settings and see a listing of the guide. Is there an easier way to see the guide? I guess I was hoping for a Guide action that would bring up a grid style guide showing what was on TV. I wasn't sure if it was the NextPVR or just something that hadn't been implemented yet. Thanks, Josh
Luke 42243 Posted September 25, 2015 Posted September 25, 2015 have you been following the release announcements? we have a full guide interface http://emby.media/community/index.php?/blog/1/entry-244-more-improvements-for-the-android-tv-and-fire-tv-app/
ebr 16335 Posted September 25, 2015 Posted September 25, 2015 Sounds like you are running a really old version of the app. Go to the play store on your NP, scroll to the bottom where it says "Updates" and select Emby.
CalypsoCowboy 4 Posted September 26, 2015 Author Posted September 26, 2015 What is the current version? It looks like I'm on 1.1.05g and it was updated on 9/20/2015. But at least on the Nexus Player I don't see any updates to new versions. I've got the Nexus Player set to auto update apps.
ebr 16335 Posted September 26, 2015 Posted September 26, 2015 That is the current version. Perhaps you need to explain more about what you are looking for. Right now, a line shows up on the home screen called "On Now" and the very first item in that list is a button to bring up the guide. Then, once you are playing a Live TV channel there is another button on the OSD that will bring up the guide while the current channel is still playing.
Solution CalypsoCowboy 4 Posted October 1, 2015 Author Solution Posted October 1, 2015 Okay, I can't completely explain what was going on but it's working now. I noticed I had an old version of NextPVR and that my guide data was basically blank. So I updated NextPVR and got the guide data working. Now I'm seeing the "On Now" where I don't recall that I was seeing it before. Thanks for the help. Josh 1
ebr 16335 Posted October 1, 2015 Posted October 1, 2015 I think you did just explain it . Glad you got it going.
