hifiaudio2 48 Posted September 23, 2015 Posted September 23, 2015 I just started using auto organize today since the HDHR kickstarter DVR "works" to record shows, but the Kodi app is poor at playback. So I am letting Emby grab the shows and present them to the native Kodi playback app. But since the HDHR app does not currently have a setting just to get "new" episodes, once the episode is removed from the HDHR folder and put into the folders that Emby uses, the app will record that episode of the show again if it comes back on. Will Emby ignore this or create a duplicate episode in its folder?
Happy2Play 9800 Posted September 23, 2015 Posted September 23, 2015 Since there is a "overwrite existing episodes" option it should fail to process unless option is enabled.
