Angelblue05 4132 Posted September 23, 2015 Posted September 23, 2015 (edited) I went ahead and checked out the issue with TV Tunes. The problem seemed to happens when TV Tunes is enabled, but no custom path were set (the user decides not to sync their Emby themes to Kodi). The custom version I've put together should correct the auto play issue and you can use it until the next version of tv tunes (which should contain the final fix) is released by the author in the official Kodi repository. Thanks everyone for testing and confirming if the fix works for you or not! Edit: This is the fix that will be pushed to the official repo, please download and install from zip in Kodi: https://drive.google.com/file/d/0B1v3j95wKopxU1FNR1YyYTBqNDQ/view Edited September 23, 2015 by Angelblue05 1
