cmweekes 0 Posted September 21, 2015 Posted September 21, 2015 At the time one user was using the live TV. I have no screens because the server crashed and had to be restarted. My system: AMD FX-8350 Eight-Core Processor 4.00GHz 16GB Memory Windows Serer 2012 No other application are running on this server it is only for Emby. Log.txt Log2.txt Transcode.txt
Luke 42185 Posted September 21, 2015 Posted September 21, 2015 try changing yoru auto-organize setup. it looks like you have auto-organize pointed at a folder that is already nicely sorted, and it's going crazy every 5 minutes trying to re-organize those files. i would turn that off.
cmweekes 0 Posted September 22, 2015 Author Posted September 22, 2015 Thanks for the quick reply and I hate to trouble you again but I can figure out how to turn off auto-organize. I look at Auto-Organize and don’t see anything checked. I also looked under Live-TV but didn’t see anything. I have attached screen shouts of both. Any assistance would be greatly appreciated
Luke 42185 Posted September 22, 2015 Posted September 22, 2015 Sorry, my mistake. I think my response was meant for another topic.
Luke 42185 Posted September 22, 2015 Posted September 22, 2015 this might be caused by the guide refresh. the dev server has some improvements that make it more efficient if you would like to try that. You can install on top of your existing installation http://mb3admin.com/downloads/dev/server/setup.exe Please note the first guide refresh will be the same as before, but subsequent refreshes will be more efficient and may help with this situation.
