cw-kid 192 Posted September 21, 2015 Posted September 21, 2015 (edited) Hi On my brothers laptop I want to put him on the stable repo now. So I uninstalled the beta repo and uninstalled the beta version of the Emby add-on I then installed the stable repo and the stable version of the add-on and reset the local DB etc. However in Kodi its prompted to update from v.1.1.39 to what ever the latest beta version is of the add-on. I tried uninstalling the repo and add-on several times, deleting their folders in the Kodi userdata\addon_data and \addons Everything seems to be working OK apart from in Kodi add-ons - Available updates its showing there is an update available etc. Thanks Edited September 21, 2015 by cw-kid
xnappo 1611 Posted September 21, 2015 Posted September 21, 2015 Check the packages folder for a zip with a newer version in it.
cw-kid 192 Posted September 21, 2015 Author Posted September 21, 2015 Good suggestion! But there was only 3 emby packages in that folder and they were all older versions. I deleted them anyways. Kodi is still saying there is an Emby add-on update available for version 1.1.43
