Spaceboy 2573 Posted September 19, 2015 Posted September 19, 2015 Hi, can anyone recommend a currently available dvb s2 quad tv tuner? i have a working tbs6984 but i want to add a second. i got a tbs6985 now replaced with a tbs6905 and i cannot get either to scan all frequencies in the uk. i should take this up with tbs but i can't be arsed i just want to buy a new one that will work. any recommendations?
pünktchen 1411 Posted September 19, 2015 Posted September 19, 2015 It depends on how much money you are willing to spend. I would go with Digital Devices. They have the best DVB cards imho. http://www.digital-devices.eu/shop/en/cine-series/sets-und-bundles/15/dd-cine-s2-v6.5-und-duoflex-s2-v4-set-4-tuner-dvb-s/s2-for-pcie Expandable up to 8 tuners or 6 tuners with only one shared CAM!
mini__me 28 Posted September 19, 2015 Posted September 19, 2015 (edited) Unfortunately I don't have an answer just a fellow TBS user, I'm sure they'll fix it shortly.My server has 1x 8920, 2x 6921, 2x 6981, 1x 6964.....I have two mini dishes and a big motorised If you fancy splashing the cash you cannot beat Digital Devices kit, just seen they have a MAX S8 model with 8 tuners in one slot...awesome Edited September 21, 2015 by mini__me
Spaceboy 2573 Posted September 19, 2015 Author Posted September 19, 2015 Cheers, never seen this brand before. It's on order!
WarrenH 16 Posted September 21, 2015 Posted September 21, 2015 Blackgold http://www.blackgold.tv/ I use an older 3595 dual DVBT/DVBS (4 tuners), works perfectly
politby 88 Posted September 29, 2015 Posted September 29, 2015 I would also add my endorsement of the digital devices products. However I am starting to move my tuners out of the server and on to the network. For less than the cost of 4 digital devices tuners you can get an Elgato NetStream4Sat network tuner. I have one and am extremely happy with it together with DVBLink. Most stable platform I have had so far.
Lee 212 Posted September 29, 2015 Posted September 29, 2015 ^do not for the love of god get a blackgold...
Lee 212 Posted September 29, 2015 Posted September 29, 2015 I sold my 6984 for £80 not long ago... U missed out there!
Spaceboy 2573 Posted September 29, 2015 Author Posted September 29, 2015 (edited) I sold my 6984 for £80 not long ago... U missed out there!I know, I thought that at the time Although I've had no more luck with the s8 max, I need to get back in touch with digital devices. Didn't work properly in my test setup and I thought that was due to not having 4 feeds connected, moved it to my live PCs and still the same. Could be because I have it connected to 4 feeds from an Octo lnb but I can't see why it would be different to using a quad (not a quattro, had to read up on that!). All 8 tuners working but none pick up the vertical frequencies in the low range. If only I could somehow combine the 6905 and the s8 max I'd be golden! Edited September 29, 2015 by Spaceboy
Spaceboy 2573 Posted October 17, 2015 Author Posted October 17, 2015 so, i went back and tried the s8 max again, its all working now. i think possibly i may have had a slightly loose connection on one feed and i guess the s8 max's magic where it produces 8 streams from only four feeds needs all the feeds working perfectly. how does it do that by the way? anyway i now have up to 24 encrypted stream available at any time. should do for a while!
