Danee 57 Posted September 18, 2015 Posted September 18, 2015 I have absolutely no clue about Vera, but have you tried running a netstat in a cmd session on the whs box?
cw-kid 192 Posted September 18, 2015 Author Posted September 18, 2015 OK I managed to properly uninstall the UPnP Event Proxy plug-in and its gone in the top list now. Still slow scenes in Vera after all that. If I run NETSTAT on the WHS there is a massive list of port numbers listed.
chef 3811 Posted September 18, 2015 Posted September 18, 2015 OK I managed to properly uninstall the UPnP Event Proxy plug-in and its gone in the top list now. Still slow scenes in Vera after all that. If I run NETSTAT on the WHS there is a massive list of port numbers listed. Yeah! The headaches of Vera plugins! Let me tell you... Their Lua/Luup platform is extremely finicky and unstable! For instance if your version of their UI is running smoothly, then they actually suggest you DO NOT UPDATE from that version, even if a new one is released. Far from what we are use to here at emby, eh!? Lua code is also very flakey, not solid like JavaScript/jquery and not even close to .net (based on the fact that you don't have to actually declare variables as any sort of type!) you can literally change a variable type in the middle of scripting. It reminds me of how lenient vbscript was... Anyway back to the issue at hand! 2 minutes is ludacris! We need to figure this out.
cw-kid 192 Posted September 19, 2015 Author Posted September 19, 2015 netstat -b shows the process names, here is what I see for Emby, the IP address being that of the WHS 2011 server. [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61671 emby:https ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61672 104.28.23.116:http ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61673 emby:http ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:63063 api:https CLOSE_WAIT I am 99% sure Emby is causing this issue with Vera running slowly and why the heck would the memory usage on the Vera go up by about 30% when Emby is running, thus probably causing the slowness in the Vera web GUI for the scenes. Devices are not affected however and they turn on / off instantly OK all the time.
cw-kid 192 Posted September 19, 2015 Author Posted September 19, 2015 Not sure what 104.28.23.116 is? It ping's and is something to do with a website called Cloudflare http://104.28.23.116/
CBers 7573 Posted September 19, 2015 Posted September 19, 2015 Cloudflare is part of the Emby web hosting infrastructure.
cw-kid 192 Posted September 19, 2015 Author Posted September 19, 2015 I just tried stopping a load of my application services on my WHS 2011 box to try and rule out anything else causing the issue and the only thing that makes Vera quicker is killing Emby. Running perfmon /res loads the windows Resource monitor, one thing I can see is that Emby is constantly using some kind of multicast IP address of 239.255.255.250 I couldn't really see any active connections to the Vera box IP in this resource monitor.
chef 3811 Posted September 19, 2015 Posted September 19, 2015 netstat -b shows the process names, here is what I see for Emby, the IP address being that of the WHS 2011 server. [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61671 emby:https ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61672 104.28.23.116:http ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:61673 emby:http ESTABLISHED [MediaBrowser.ServerApplication.exe] TCP 192.168.0.x:63063 api:https CLOSE_WAIT I am 99% sure Emby is causing this issue with Vera running slowly and why the heck would the memory usage on the Vera go up by about 30% when Emby is running, thus probably causing the slowness in the Vera web GUI for the scenes. Devices are not affected however and they turn on / off instantly OK all the time. So, there isn't the delay when you turn each device on/off, it is just when you are running scenes?? Also, wondering what "CLOSE_WAIT" is a report of from netstat...?
cw-kid 192 Posted September 19, 2015 Author Posted September 19, 2015 Hi Yes only scenes, devices are not affected.
cw-kid 192 Posted September 19, 2015 Author Posted September 19, 2015 Also, wondering what "CLOSE_WAIT" is a report of from netstat...? I'm not sure, maybe @@Luke can give us some insight.
CBers 7573 Posted September 19, 2015 Posted September 19, 2015 CLOSE_WAIT Indicates passive close. Server just received first FIN from a client. https://support.microsoft.com/en-gb/kb/137984
cw-kid 192 Posted September 20, 2015 Author Posted September 20, 2015 Looking in the Emby server log this morning, I can see a couple of errors in there, not sure if related to this issue in anyway? They can be seen here on this thread. Also I turned off all the DLNA options in Emby but it still shows this in the log: Info - App: Loading MediaBrowser.Dlna, Version=3.0.5724.3, Culture=neutral, PublicKeyToken=null
AgileHumor 123 Posted September 20, 2015 Posted September 20, 2015 (edited) @@cw-kid, I never was able to resolve this...but wanted to mention also noticed the UI5 became unusable via the WebGUI. Remote Apps or http get commands would fire scenes or light control and lights instantly, but pushing a button in the UI5 webgui would take forever. I also have Emby, and nobody on the Vera forums shared similiar issues when I posted about it. It started about 6+ months ago. I recently started moving some things from Vera to HomeSeer as PLEG/UI7 was unusable to program (as it also would take minutes to save PLEG settings)...I wonder if my experience could have been related to also having Emby. Not enough data to correlate, but seems related enough to share. Edited September 20, 2015 by AgileHumor
chef 3811 Posted September 20, 2015 Posted September 20, 2015 I just can't se to replicate this. I wonder if it has to do with Emby Connect... Maybe?? I haven't used Connect so it is potentially the only differences in our setup, besides our client choices.
AgileHumor 123 Posted September 20, 2015 Posted September 20, 2015 I do use/have EmbyConnect. Maybe something I'll test as I still need to control UI5 as I switch over many months.
cw-kid 192 Posted September 21, 2015 Author Posted September 21, 2015 @@AgileHumor Thanks for also confirming you had similar issues. Certainly sounds the same as its only the Vera web GUI that is slow running scenes, all Vera mobile apps, Aeon minimote handsets, and sending HTTP requests to Vera via Curl command line all work perfectly and the scenes run instantly. just not in the web GUI when Emby is also running. Could you please list the Vera plug-ins you had installed? And also the Emby Server plug-ins you have installed? Emby Connect, I have setup my remote users to use Emby Connect for logging in to various Emby clients etc.
cw-kid 192 Posted September 21, 2015 Author Posted September 21, 2015 (edited) Here's my list of installed Plug-ins perhaps so users with this issue can compare. Vera Plug-ins Count DownTimer Wake-on-LAN CurrentCost EnviR Energy Monitor iTemp Plug-in VeraAlerts Squeezebox Control DLNA Media Controller & UPnP Event Proxy KodiRemote (XBMCState) MultiSwitch EMBY Server Plug-ins Auto Box Sets DVBLink TV Dropbox Kodi Sync Queue What I don't understand is when running the TOP command on the VERA box in terminal when Emby is not running the memory usage is about 140% and everything in the Vera Web GUI runs OK. If I then launch Emby server you can see the memory usage of the Vera box climbing and can go as high as 190% or more and then running the scenes in the Vera web GUI is delayed. Cheers Edited September 21, 2015 by cw-kid
AgileHumor 123 Posted September 21, 2015 Posted September 21, 2015 Sure! I'm worried the problem is with Vera's network UPNP autodisover then Emby...but it could be. Vera Plugins: Philips Hue Russound Global Cache Foscam Somfy Virtual Switch PLEG Ping Sensor Day Night Wakeup Light Simple Alarm Battery Monitor Multisiwtch SysMon Emby: Auto Box Sets Cover Art Google Drive Sync ServerWMC Kodi Sync Queue (new) PlayOn (new)
cw-kid 192 Posted September 21, 2015 Author Posted September 21, 2015 Vera support have just emailed me again: We’ll need to do some more tests to properly identify the issue and see if it’s logged in the LuaUPnP log. At the moment I can tell you the port which was kept busy on the Vera unit, port 49451, as it can be seen from the log output for netstat I ran on the 18th : Proto Recv-Q Send-Q Local Address Foreign Address State tcp 0 0 192.168.0.100:49451 192.168.0.10:62882 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62874 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62881 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62876 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62873 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62872 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62883 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62875 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62886 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62878 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62885 TIME_WAIT - tcp 0 0 192.168.0.100:49451 192.168.0.10:62880 TIME_WAIT - .100 is the Vera box .10 the WHS 2011 server running Emby. 1
cw-kid 192 Posted December 10, 2015 Author Posted December 10, 2015 Hi An update I never got to the bottom of this problem however after recently replacing my VeraLite UI5 box with a new VeraEdge UI7 box this problem has gone. I no longer have issues with scenes running slowly in the Vera web GUI when Emby server is also up and running on the network. 1
chef 3811 Posted December 10, 2015 Posted December 10, 2015 It is funny you should bring this topic back up because I have been experiencing a huge lag with my veralite. Each light turns off independently instead of the whole scene activity at the same time. Hearing about your experiences makes me wonder if I too should update to the edge.
AgileHumor 123 Posted December 10, 2015 Posted December 10, 2015 @@cw-kid, have you ever tried HomeSeer? I switched from Vera and have been much happier. Runs on Windows/Linux, or they have some appliance like devices like the Vera. I've been using Kodi/Emby with a plugin to interface HomeSeer....just like you can do with Vera and Kodi.
cw-kid 192 Posted December 10, 2015 Author Posted December 10, 2015 No not really used HomeSeer. I did use mControl with WIndows MCE for a while in the past though before I got my first Vera box. I guess I could run HomeSeer as my HP Microserver is running as a file server 24/7. The VeraEdge UI7 has been OK, had some issues with some devices but on the whole its not too bad. I would probably buy a Fibaro Home Center 2 next time.
