ipodfreek 2 Posted September 18, 2015 Posted September 18, 2015 Has anyone else had this issue? I run Emby as it's own profile on my iMac. It stays logged in so Emby can be used on our TV's. After a period of time, the process seems to completely freeze, and I cannot connect to the server to watch movies. I have to come upstairs to the iMac and force quit the Emby process in Activity Monitor. Once restarted it works fine for (I think) a day or so, then dies again. I'm now running version 3.0.5724.4, but it was doing this in previous versions too. Anyone? Thanks. I've attached three recent log files. Thanks again! server-63578044800.txt server-63578116287.txt server-63578044796.txt
Plaix 0 Posted September 18, 2015 Posted September 18, 2015 I have a similar issue. Whenever I try to remotely wake my Mac, it completely freezes. It only happens when wakeing through emby. It works for local access, but not when I'm away from home. I then habe to hard reset my mac, since it wont suspend nor display anything.
ipodfreek 2 Posted September 18, 2015 Author Posted September 18, 2015 My Mac is awake. I don't have have it going to sleep. It just seems like after a day or so the Emby process gets borked. Any ideas are appreciated.
Plaix 0 Posted September 19, 2015 Posted September 19, 2015 What do you mean wake through emby? Emby Server is running, but the Mac is suspended. When I start the Emby App on my Android Phone or Web Browser (via DynDNS) it Wakes (on LAN) the Mac but crashes it. When I try the same with other services, it won't happen.
ipodfreek 2 Posted September 19, 2015 Author Posted September 19, 2015 Any ideas? Did my log files help? Thanks.
ipodfreek 2 Posted October 18, 2015 Author Posted October 18, 2015 Still nothing on this? I have to constantly go to the Mac and force quit the Emby process because it freezes.
Luke 42237 Posted October 18, 2015 Posted October 18, 2015 can you try installing from the website on top of your existing install? thanks.
ipodfreek 2 Posted October 22, 2015 Author Posted October 22, 2015 I don't wanna jinx it, but so far that actually seems to have fixed it. I'll let you know if it breaks again. (fingers crossed) Thanks!
