Mopar_Mudder 14 Posted November 30, 2013 Posted November 30, 2013 I have my HTPC hooked to a regular TV plus a receiver that goes to my projector. Through the receiver everything works great, HD audio and all. But on the TV it seams I can only play mpeg videos. If I play a DVD folder rip I have picture but no sound, if I play a Bluray folder rip I get an error message about sound and MBT shuts down. Also if I try to go into the sound settings in MBT I get an error that the LAV filters could not be found, same with configure subtitles. Also since installing the MB Server and MBT the weather gadget on my W7 desktop is messed up. It is translucent and the colors are wrong.
Luke 42233 Posted November 30, 2013 Posted November 30, 2013 try uninstalling and re-install lav, that will fix the configure buttons.
Mopar_Mudder 14 Posted November 30, 2013 Author Posted November 30, 2013 I can't even find LAV, could it be because I have the Shark Codec pack installed. Everything seemed to be working so I never thought much about it, until I tried and use it on the TV.
Luke 42233 Posted November 30, 2013 Posted November 30, 2013 shark installs lav but not to the default location, so we're unable to find it. eventually we'll have a better way of doing that.
