ngerg 19 Posted September 17, 2015 Posted September 17, 2015 All, I've been working on building a Wiki page for Emby for Kodi. As a long time Kodi user who has recently adopted Emby as a media server, I built it over on the Kodi wiki: http://kodi.wiki/view/Add-on:Emby_for_Kodi It's about 90% done, but I wanted to share. If anyone has any comments on how to improve the wiki page or any errors I might have made, please post them below or edit the wiki yourself. I'm planning on taking all of the information I've built in the Kodi wiki and using it to update the wiki on the Emby for Kodi GitHub page: https://github.com/MediaBrowser/Emby.Kodi/wiki Ideally these two pages will stay in sync and reference each other, but I had to start somewhere. 9
ngerg 19 Posted September 17, 2015 Author Posted September 17, 2015 I'd like to take a moment here and thank the developers of both the Emby for Kodi addon and Emby itself for all of their hard work. Thank you and keep up the great work. 3
xnappo 1611 Posted September 17, 2015 Posted September 17, 2015 Excellent work - thanks for taking this on! Just two comments: First please make sure to mention that this addon completely takes over your DB, so if you are just experimenting you should make a backup. Second, I know confluence doesn't support it, but the #1 question we get asked is how to get links into collections from the home screen - so an example from a popular skin showing that would be good too. Thanks again! xnappo
ngerg 19 Posted September 17, 2015 Author Posted September 17, 2015 Excellent work - thanks for taking this on! Just two comments: First please make sure to mention that this addon completely takes over your DB, so if you are just experimenting you should make a backup. Second, I know confluence doesn't support it, but the #1 question we get asked is how to get links into collections from the home screen - so an example from a popular skin showing that would be good too. Thanks again! xnappo Will do, thanks for the input. One quick question, who are all of the developers of this addon? I would like to make sure to give everyone credit on the wiki page.
ngerg 19 Posted September 17, 2015 Author Posted September 17, 2015 Oh, one more request; I would also like to know where I can find an emby logo that I can use for the kodi wiki page.
e123enitan 276 Posted September 17, 2015 Posted September 17, 2015 All, I've been working on building a Wiki page for Emby for Kodi. As a long time Kodi user who has recently adopted Emby as a media server, I built it over on the Kodi wiki: http://kodi.wiki/view/Add-on:Emby_for_Kodi It's about 90% done, but I wanted to share. If anyone has any comments on how to improve the wiki page or any errors I might have made, please post them below or edit the wiki yourself. I'm planning on taking all of the information I've built in the Kodi wiki and using it to update the wiki on the Emby for Kodi GitHub page: https://github.com/MediaBrowser/Emby.Kodi/wiki Ideally these two pages will stay in sync and reference each other, but I had to start somewhere. Nice work
Angelblue05 4132 Posted September 17, 2015 Posted September 17, 2015 Oh, one more request; I would also like to know where I can find an emby logo that I can use for the kodi wiki page. https://github.com/MediaBrowser/Emby.Resources/tree/master/images/Logos
ngerg 19 Posted September 17, 2015 Author Posted September 17, 2015 (edited) Thanks Angelblue Another question: What exactly do the following options do? Sync Options tab "Sync Specials Ordering" "Max change set size" under "Use Incremental sync at startup" Thanks Edited September 17, 2015 by ngerg
Angelblue05 4132 Posted September 17, 2015 Posted September 17, 2015 Sync specials ordering is if you want to have your special episodes to display within seasons. Having the option enabled will sync when the special episode aired (before season, episode). Max change set size is for the start up sync (with the server plugin). If the server plugin returns more than x items, fall back to the old ways of doing the start up sync (which is faster at some point). @ could probably give you a better explanation.
xnappo 1611 Posted September 17, 2015 Posted September 17, 2015 Devs: angelblue05, xnappo, null_pointer, marcelveldt, im85288, jurmb84(sync plugin)
gmacman 3 Posted September 18, 2015 Posted September 18, 2015 Brilliant! Being new to both Kodi and Emby this is just great.
skank 85 Posted September 23, 2015 Posted September 23, 2015 This is truly great ! Very nice work for all of you !
skank 85 Posted September 23, 2015 Posted September 23, 2015 I´ve read and it already looks good. However it still needs to tell how to use tags, nodes, and how to populate main menu items, so stuff doesnt populate through each other
ngerg 19 Posted September 23, 2015 Author Posted September 23, 2015 (edited) Tags and Nodes area part of Kodi, not the addon. They currently have their own kodi wiki pages, so I don't really want to replicate that data onto the kodi wiki page for an addon. When I get a chance to update the emby wiki page for the addon, I'll try to add a few links to those kodi wiki pages. As far as populating the main menu with additional itms, I'm planning on adding something, to show the basic mechanics, but haven't decided how I want to approach that yet. But thanks for the input Skank Edited September 23, 2015 by ngerg
skank 85 Posted September 23, 2015 Posted September 23, 2015 Dont know how to tell this But i have some views in emby ui and i dont get those exact same in kodi a wiki should talk about this how to do it for now its try and see with good luck lol
ngerg 19 Posted September 23, 2015 Author Posted September 23, 2015 Dont know how to tell this But i have some views in emby ui and i dont get those exact same in kodi a wiki should talk about this how to do it for now its try and see with good luck lol Ah, that makes more sense. I'll look into it and see what I can do with the wiki.
