pir8radio 1313 Posted September 16, 2015 Posted September 16, 2015 This may be a user setting but I could not find one.. My account has the icon names below each media icon.. but my users just see icons with no name? Any idea where this setting is? Users see:
AdrianW 1058 Posted September 17, 2015 Posted September 17, 2015 (edited) I'm not in front of Emby right now - but IIRC, go to your user preferences (click the user icon at the top right), select "homepage", towards the top is a list of four entries for what appears on your homescreen, and choose the appropriate item - I think there's two, maybe three, versions of "My Media" - one of those must include the caption. Edited September 17, 2015 by AdrianW 1
AdrianW 1058 Posted September 17, 2015 Posted September 17, 2015 There's actually three versions for "My Media" (My Media, My Media (small) and My Media (buttons) - but, all three include text. So, something must have gone wrong. It's probably worth trying those other options to see if it fixes the issue though.
Luke 42185 Posted September 17, 2015 Posted September 17, 2015 clear your browsing data and the problem should go away
pir8radio 1313 Posted September 26, 2015 Author Posted September 26, 2015 clear your browsing data and the problem should go away so your saying my peeps see things as normal, i am the only one that sees it jacked up because if some cache stuff? 10-4 i can deal with that...
Luke 42185 Posted September 26, 2015 Posted September 26, 2015 we used to have a setting for this in user profile settings. along the way i must have decided to trim some fat and eliminate it, which means you can't toggle it back. but the setting is only saved in the browser, so it's easily cleared.
