Redshirt 1487 Posted December 2, 2013 Posted December 2, 2013 Updated the title, my OCD couldn't handle the misspelling of 'a lot'. 1
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 i also open a post here with all the logs and screenshots and everything that been shared in regards to my issue but no luck yet http://forum.flexraid.com/index.php/topic,3080.0.html Thanks
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 (edited) Updated the title, my OCD couldn't handle the misspelling of 'a lot'. Hello Red , Change it to: Install and setup FlexRAID Combo 1st Time and Need help pls as i am not able to edit the title apologies in advance Edited December 2, 2013 by Airbender
swhitmore 781 Posted December 2, 2013 Posted December 2, 2013 Updated the title, my OCD couldn't handle the misspelling of 'a lot'. That placement of the colon is killing me too
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 That placement of the colon is killing me too Hi how do i edit the title it seems i dont have that option
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 (edited) HelloStarting over now : un-install F Raid but under C drive i am not able to delete one folderso i got screen shots of the entire processStarting over freshHere are screen shots Edited December 2, 2013 by Airbender
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 Hello Next set of screenshots now the speed show 25MBs so not sure if that fast or slow
Airbender 128 Posted December 2, 2013 Author Posted December 2, 2013 Hi Things looking better it could be broken raid or something but by re install Raid F now i am able to see progress at 2% Hope thing goes well ! Thanks
Airbender 128 Posted December 3, 2013 Author Posted December 3, 2013 Hello The Raid keep failing and my pc restarted while NAS is still active made me wonder if the issue is with my PC or The NAS unit i am using : Sans Digital 8-Bay eSATA RAID 0/1/10/5/JBOD Tower Storage Enclosure w/ 6G PCIe Card TR8M+B (Black) with Rocket Raid Card 642L as JOBD so i went to MS Event logs and found these logs under error I see This error:The device, \Device\Scsi\rr640l1, did not respond within the timeout period.and i see this error:The device, \Device\Harddisk0\DR0, is not ready for access yet.The device, \Device\Harddisk3\DR3, is not ready for access yet.The device, \Device\Harddisk4\DR4, is not ready for access yet.The device, \Device\Harddisk4\DR6, is not ready for access yet.The device, \Device\Harddisk5\DR5, is not ready for access yet.The device, \Device\Harddisk9\DR28, is not ready for access yet.The device, \Device\Harddisk5\DR25, is not ready for access yet.The device, \Device\Harddisk10\DR27, is not ready for access yet.The device, \Device\Harddisk10\DR24, is not ready for access yet.The device, \Device\Harddisk4\DR6, is not ready for access yet.also see thisFaulting application name: ASPFSVS64.exe, version: 2.0.0.2, time stamp: 0x4cf70fcaFaulting module name: ASPFSVS64.exe, version: 2.0.0.2, time stamp: 0x4cf70fcaException code: 0xc0000005Fault offset: 0x000000000000a356Faulting process id: 0x70cFaulting application start time: 0x01ceec0d6fe5fd7dFaulting application path: C:\Program Files (x86)\ASUS\Disk Unlocker\ASPFSVS64.exeFaulting module path: C:\Program Files (x86)\ASUS\Disk Unlocker\ASPFSVS64.exeReport Id: b01d3ab8-5800-11e3-9858-c8600022b15falso see this from AMD RaidTask 20 timeout on port 1 target 1 at LBA 0x00 (Length 0x1)my system is running on 2 SSD on Hardware Raid 1 with windows 7 x64bitalso see thisThe driver detected a controller error on \Device\Ide\IdePort1.Not sure why bitlock on windows 7 is active but i never set it upEncrypted volume check: Volume information on J: cannot be read.also see thisEncrypted volume check: Volume information on cannot be read.and see NTFS error on drive GThe default transaction resource manager on volume G: encountered a non-retryable error and could not start. The data contains the error code.and see thisThe device, \Device\CdRom0, has a bad block.Not sure what this mean or if the drives going bad or if the unit is bad, if the unit which i got on october is bad i can return it for full refund as it is not very stable and i change 2 e-Sata card already since i got this unitdid anyone else run into issue like this ?? Thanks
