phoenixaus 3 Posted January 13, 2017 Posted January 13, 2017 Hi Luke, Yes, I have refreshed manually from the scheduled Tasks twice this week hoping it would address. Once the refresh was completed, I definitely had more images, but i'm yet to see any bio information though. I just checked and saw that the last run had been cancelled, so I have manually run this again. It kicked off at 47%, so will see what it does when completed.
Luke 42197 Posted January 13, 2017 Posted January 13, 2017 Thanks for the update. Be aware that if you (or MCM) make changes to the people folder without using Emby, you will need to run the refresh people operation in order for Emby to pickup the changes.
phoenixaus 3 Posted January 13, 2017 Posted January 13, 2017 Hi Luke, Refresh completed, same deal, no bio information. Is the Bio info sourced by Emby using the metadata downloader (which I don't have any showing) on demand?
Happy2Play 9802 Posted January 13, 2017 Posted January 13, 2017 Not sure anymore but you should still see these options.
phoenixaus 3 Posted January 13, 2017 Posted January 13, 2017 Thanks Happy2Play, I don't have any of those options under people. Mine is blank Screenshot is in my original post (#96)
Luke 42197 Posted January 13, 2017 Posted January 13, 2017 there is an issue with that screen that is resolved for the next release. in the meantime you could use the online web app to configure http://app.emby.media It looks like you might have turned off too many things most likely.
pünktchen 1410 Posted January 13, 2017 Posted January 13, 2017 Just a question: do i have to enable metadata download per library or is the people download independent of this?
